1983 200E CARB PROBLEMS
Old 05-29-2003, 10:00 AM
LORENTA's Avatar
Default 1983 200E CARB PROBLEMS
I HAVE A 1983 HONDA ATC 200E THAT IS HAVING FUEL PROBLEMS. GASOLINE CONTINUES TO FLOW THROUGH THE AIR CLEANER. I HAVE REPLACED THE FLOAT IN THE OLD CARB WITH THE SAME RESULTS. I WENT TO THE EXPENSE OF PURCHASING A NEW CARB HOPING THERE WAS SOMETHING WRONG WITH THE OLD ONE. THE SAME THING IS HAPPENING WITH GAS FLOWING THROUGH THE HIGH SPEED JET OPENINGS. THE FLOATS ARE PLASTIC AND DO NOT APPEAR TO HAVE ANY WAY OF ADJUSTING THEM. THE NEEDLE AND SEATS ARE IN PERFECT CONDITION AND I HAVE ALSO CLEANED OUT THE GAS TANK TO REMOVE ANY DEBRIS THAT COULD CAUSE A STICKING NEEDLE. I AM FIRMLY CONVINCED THE PROBLEM LIES IN THE FLOAT NOT SHUTTING OFF THE FUEL FLOW BUT I AM STUMPED ON WHAT TO DO NEXT. ANY SUGGESTIONS?
Old 05-29-2003, 02:26 PM
Riznaptor's Avatar
Isnt there a hole in the bottom of the carb as an overflow? I dont think its the float. Gas should be pouring out of an overflow before it goes through your air box.
I know I have seen this before with my old raptor. I dont remember what was wrong though. have you tried putting back in the stock jet?
Old 05-30-2003, 05:37 PM
LORENTA's Avatar
YES THERE IS A HOSE THAT RUNS FROM THE BOTTOM OF THE CARB TO THE SIDE OF IT. I HAVE NOT TOUCHED ANY OF THE JETS EITHER ON THE OLD OR NEW CARB. IT JUST PUZZLES ME THAT IT WOULD JUST START LEAKING WITHOUT ME MODIFYING OR MESSING WITH ANYTHING. I COMPARED BOTH CARBS TO INSURE EVERYTHING WENT BACK TOGETHER AS ORIGINALLY ON THE BIKE. ANY OTHER INSIGHT WOULD BE APPRECIATED.
Old 05-30-2003, 08:59 PM
dzzy's Avatar
There is no hose that runs from the bottem to the side of the carb. There should be a hose that runs from the bottem of the carb to underneath the machine which is a drain hose for the carb and not essential really. The other spigot on the side of the carb is the vent for the float bowl. The hose that belongs on it is routed along the side of the frame by where the wires come up on the left side, this spigot must be open to atmosphere or the machine will never run right.
Old 06-04-2003, 10:08 AM
LORENTA's Avatar
IT WORKS! I DID WHAT YOU SUGGESTED AND IT RUNS GREAT. THANK YOU FOR YOUR HELP. I AM NOT SURE HOW THE HOSE CAME TO BE CONNECTED AS IT WAS, BUT WE ARE ROLLING NOW!
Old 06-04-2003, 02:30 PM
dzzy's Avatar
Your welcome lorenta. I have seen other people do the same.
Old 10-01-2009, 09:55 AM
scottoien's Avatar
ha ha i did the same thing last night and i could not figer it out gas was pouring out every where i got so pissed off i almost put a match th the trike
Ty Speece
07-02-2015 04:59 PM
generalpops
06-05-2015 08:23 PM
garyt1975
06-05-2015 08:53 AM
generalpops
06-03-2015 08:25 PM
kevbowe
06-01-2015 01:17 AM
Quick Reply: 1983 200E CARB PROBLEMS
