00 Rancher ES stuck in 2nd gear
Old 01-20-2004, 11:59 AM
noodle's Avatar
Default 00 Rancher ES stuck in 2nd gear
Need Help. Cannot get my 00 Rancher ES 4X4 out of 2nd gear. The ES is still functioning but won't shift even when rocking. Also, I can't even get it to shift manually. When I do manually push the gear shaft forward it will disengage the transmission but went let up it remains in 2nd gear.
Old 01-20-2004, 12:16 PM
dg37615's Avatar
does the display blink? if so that is a code pointing you to the problem. if it is blinking count the sequence of blinks. that is the code diagnosing the problem. call your dealer or get a repair manual. that will point you at the repair process. dg
Old 01-20-2004, 12:31 PM
noodle's Avatar
The display is a steady 2. No blinking. I just ordered a manual.
Old 01-20-2004, 12:47 PM
dg37615's Avatar
it's probably an angle sensor or a shift sensor. let me know. god luck. dg
Old 01-20-2004, 02:21 PM
hayve's Avatar
i get this on my 250ex, lean forward so that wheels turn no further then try, worked for me
Old 01-20-2004, 07:49 PM
noodle's Avatar
that didn't work to push forward. thanks
Old 01-20-2004, 08:07 PM
hondabuster's Avatar
Have someone rock it back and forth, while you shift with the handle. The constant mesh tranny needs movement to work.
Then when youre in nuetral, and turnon the key, what is displayed? Is it --?
Old 01-20-2004, 08:45 PM
dzzy's Avatar
That it doesn't shift manually would indicate you don't have any problem with the electronic shifting part of your wheeler. Sounds like a tran linkeage problem. I think there's a product improvement campaign on your machine having to do with the linkeage, the shift plate specifically. I believe it's a current bulletin yet, and Honda (I think) will cover that specific problem yet even though your wheeler is out of warranty. If it is a different problem, you'll probably have to pay out of your pocket.
Polaris5
08-29-2015 09:11 PM
heath legg
07-24-2015 01:01 PM
micheleLeigh
Technical and How-To Articles
07-19-2015 07:32 AM
ghost civic
07-15-2015 10:48 PM
sara durrant
07-06-2015 05:32 PM
Quick Reply: 00 Rancher ES stuck in 2nd gear
