honda 1994 trx 200 type II
Old 03-06-2004, 10:39 PM
edgethehunter's Avatar
Default honda 1994 trx 200 type II
ok people i need some help here i have honda 1994 trx 200 type II and the chain is very loose do not have manual could some tell me if there is a way to adjust tension on chain or what do have to do
any help would be great
Old 03-06-2004, 10:49 PM
pimp250r's Avatar
if it's like any other trx, on the back of the swingarm are 2 nuts you can loosen with an alan wrench, make both loose and start rotating your axle backwards until the chain gets a bit tighter, but you will need to leave some slack in there...after that just tighted em back down and you're set to go
Old 03-07-2004, 01:14 AM
KNOWSALOT's Avatar
The Facility
pimp,
You are thinking sportquads....LOL....I've made the same mistake telling this to someone before. After you've dealt with sportquads so long, it becomes habit.
edgethehunter,
Loosen the 4 17mm bolts holding the bearing carrier to the frame. Lift and support the quad so that the back tires are off the ground. There are two chain adjusters poking out the back with 12mm nuts on them. Run them up equally. If you do not, the chain will derail.
On this machine, around 3" of slack right behind the swingarm pivot bolt will be fine. It will seem loose, but when you set it back on the ground, it will tighten up a bit.
Set the machine bak on the ground and tighten the 4 carrier bolts and you are done.
Don't forget to lube the chain while you are there.
Old 03-07-2004, 11:27 AM
Thanks guys i will try that today, I check the chain and it seemed very loose when i am riding you can here it claking so will tighten and see if that does it
Thanks Again
Old 03-07-2004, 12:42 PM
pimp250r's Avatar
LOL
all I saw was trx chain and loose and I was like hey buddy here's your answer!
attention to detail pimp
[img]i/expressions/face-icon-small-smile.gif[/img]
Old 03-07-2004, 01:21 PM
It worked thank but one thing to add this is how much i do not know the two #12 nuts you adjust tension with do not forget there is bolts on the backside of them to or will break them well thanks again now i know just a little bit smarter or dumber who knows
mattcraig1
08-19-2015 03:48 PM
Polarisman1123
08-13-2015 08:13 AM
Stirling
08-11-2015 07:23 AM
toonces
07-31-2015 09:27 AM
Quick Reply: honda 1994 trx 200 type II
