VIN help for '89 250r
Old 04-02-2004, 12:00 AM
hrc200x's Avatar
Default VIN help for '89 250r
I guess my '87 250r ended up being a '89, but the VIN on the engine reads TB06E-8006250. Can someone look that up for me? How else do I tell if I have a '89 engine, ATC engine or a early TRX engine? Thanks.
Old 04-02-2004, 12:50 AM
KNOWSALOT's Avatar
The Facility
First of all, something in your Engine VIN isn't quite right........
TB06E are ATC engines and TE06E and TE12E are TRX engines
BUT....
The "8" starting off the last part of that number states it as being an 88-89 TRX engine......The "0" after the "8" can't be right at all.
BUT....
The 88-89 TRX engines used TE12E
Check your numbers again. Sometimes crud makes a number or letter appear to be something else.
Old 04-02-2004, 12:55 AM
KNOWSALOT's Avatar
The Facility
OK.....I'm going night-night soon, so here are the breakdowns......just find your number sequence.
1985 ATC250R....TB06E-2300003 and up
1986 ATC250R....TB06E-2400001 and up
1986 TRX250R....TE12E-1000001 and up
1987 TRX250R....TE12E-8000001 and up
1988 TRX250R....TE06E-8100001 and up
1989 TRX250R....TE06E-8200001 and up
If you have an R engine, it has to fall into one of the above
Old 04-02-2004, 10:20 PM
hrc200x's Avatar
I've double checked this and thats the number, maybe its a '87 ATC motor? I'll tripple check it and see whats up.
I'm temped to take off the right side cover and see if it is alteast a '89 motor with the needle bearing clutch pusher.
Old 04-02-2004, 10:41 PM
ripperupper's Avatar
Its an 89 a friend looked at them and said it was he works at the honda shop
Old 04-03-2004, 12:53 AM
KNOWSALOT's Avatar
The Facility
ripperupper,
Your friend either doesn't have any idea about Honda ATVs or didn't look at the numbers right.
ALL Honda 4 Wheeled ATVs have engine numbers beginning with TE.........there are none that start with TB
hrc200x,
The important part of that number you have that isn't adding up is the beginning letters and the begining sequence number.
Old 08-24-2013, 03:08 PM
hrc200x's Avatar
I have a picture of the vin but don't see how to post pictures. May be an 87 atc 250r motor.
Alex Rodak
09-13-2015 12:30 AM
Alex Rodak
09-12-2015 09:39 AM
Alex Rodak
09-11-2015 11:42 PM
Traci Carnahan Simmons
08-09-2015 03:00 PM
CRamshaw777
07-18-2015 05:46 PM
Quick Reply: VIN help for '89 250r
