Banshee overheating
Banshee overheating
First, how do you know it's overheating? Because it's coming out of the overflow tube and spilling onto your exhaust? Could be overheating or it could be this:
http://kuoi.asui.uidaho.edu/~john/tips.html
Next, get a temp gauge! That way you know if you're getting hot and can shut down before you truly do overheat:
http://cgi.ebay.com/ebaymotors/ws/eB...RK%3AMESE%3AIT
Colby
Colby
#13
Banshee overheating
Lol, why don't you think about what you just said...
how would relocating a coolant tank have ANY impact on overheating? It holds fluid, it doesn't effect the cooling of the motor.
Now, read the link I provided above. It explains what moving the coolant tank does..
Or let me summarize it for you. The factory location and routing of the overflow hose allows fluid to spill into the overflow hose when you go up steep inclines. You then level out and pressure pushes the fluid out and onto the exhaust. People think they are overheating when they are not. Moving the tank keeps this from happening, that's all it does.
Colby
Colby
#14
Banshee overheating
My 2 cents -
Banshee overheating is overrated. I ran my 2000 at Glamis for 4 seasons and it never overheated; fmf pipes, pro flow air filter (lid off), reeds, stock radiator, stock head, and 50/50 af/distilled water (prestone af) and 320 mains . If there is water on the pipes from the overflow it is normal. All Banshees do it. If it is gurgling, the impeller as many have mentioned is bad or you are running lean. Oh I believe the impeller is plastic. If you run it at low speeds or labor the motor at slow speeds for an extended time at temps ~ 90 degrees it may overheat.
#15
Banshee overheating
The problem is no one is really qualified to answer as to Banshee overheating...unless you have a temp gauge. Your coolant doesn't have to be boiling over for your temps to be WAY too high. Having a temp gauge, I can verify that overheating is a serious problem for my riding style (woods and trails mainly). Our motors don't like low RPM's. The other situation where I get too hot is if I am hung up and revving the motor and shifting my weight trying to get traction. High RPM, poor airflow through the radiator gets the motor overheating quick.
Colby
Colby
#16
MikeyBoyesq
08-10-2015 11:11 AM
07-07-2015 11:00 PM
