stock banshee vs stock kfx 400
Old 07-03-2004, 02:50 PM
PrIm4L's Avatar
Default stock banshee vs stock kfx 400
which 1 is the fastest and strongest?
Old 07-04-2004, 03:09 AM
bulldogz400's Avatar
Neither the 250EX rules ALL!
......but more truthfully the Banshee is faster. Not sure about which is stronger, I wasn't aware that quads lift weight!
Old 07-04-2004, 06:21 AM
JohnnySplat's Avatar
KFX - 400cc single 4-stroke
appx. 28 hp
Top speed - about 64 mph
Banshee - 350cc twin 2-stroke
appx. 39 hp
Top speed - about 72 mph
Enough with the numbers though, fastest is obviously shee, in accel and top speed. About strongest i dont know what that means, but if it might in any way be linked to torque, the kfx has more low rpm torque.
Old 07-04-2004, 04:00 PM
jed250's Avatar
appx. 28 hp
appx. 39 hp
Stronger as in, built Stronge rmaybe? BUILT FORD TOUGH. That means Ford is strong.
Old 07-04-2004, 04:10 PM
Yfz450VsBanshee's Avatar
appx. 28 hp
appx. 39 hp
39hp for a stock banshee?
Old 07-04-2004, 06:42 PM
jed250's Avatar
appx. 28 hp
appx. 39 hp
Well my car has 120hp.
Old 07-04-2004, 07:51 PM
craZ400's Avatar
appx. 28 hp
appx. 39 hp
You obviously haven't ever ridden a Z, top speed is 70-71mph stock. But a $15 15 tooth front sprocket will change that.
Old 07-04-2004, 08:56 PM
FaStLaNe's Avatar
LMAO, Z's don't hit 71 stock!! My brother has a KFX and my R has a 13 tooth front sprocket and I still have A LOT more top speed than him!
Old 07-04-2004, 08:57 PM
FaStLaNe's Avatar
http://www.kg4vpv.com/~ncliborne/ltz400.htm
Old 07-04-2004, 10:21 PM
craZ400's Avatar
calculate at 8500rpm, which is the rev limit on a z, and you get 70.74. I call that close enough to 70-71. Do your homework before you talk smack, PUNK!
Quick Reply: stock banshee vs stock kfx 400
