twister hammerhead 150cc go off road go kart
Old 03-15-2009, 08:41 AM
RonV's Avatar
Default twister hammerhead 150cc go off road go kart
<div class="FTQUOTE"><begin quote>Originally posted by: kansasguy1976
Hey , brand new here. Got an issue with my '05 HH 150 not starting. will start with ether but not by itself. Though it might be the carb, so I pulled it and did a thorough cleaning. I replaced the coil, rectifier, CDI, and still no luck. Any help out there??????</end quote></div>
A lot of times there are problems with that rubber elbow connecting the carb to the head. The rubber will separate and allow air to enter there. Once it is running, spray some ether around that rubber elbow - if the engine surges, then you have an air leak. Replace the elbow, it's about $20. I had an 05 Carter Talon, which is basically the same buggy, and it did the same thing. It was very hard to start, but once it warmed up, it would run. The other thing you want to do, if you already haven't done so, is adjust the valves.
If this doesn't help, go to Buggynews.com. That is THE site with info on those buggies.
  #702
Old 05-19-2009, 05:26 AM
wtf is that?!'s Avatar
Default unknown..
um does anyone know where there is a site or a person who knows what this buggy is or what year or any infomation would be appreciated thanks
(pictures are in link)
Login | Facebook
  #703
Old 05-19-2009, 05:29 AM
Default part 2
all i know about it, is that it is a twister buggie 150cc single seater 4 stroke and thats it, if you need to see more pictures just ask thanks...
  #704
Old 05-19-2009, 03:58 PM
jlabrier's Avatar
Login | Facebook
If you look at the Vin # located behind the seat that will tell you what yr it is. The 10th digit of the vin # indicates the yr. for example if the 10th digit is a 5 its a 2005 if the 10th digit is a 7 its a 2007.
Hope this helps
  #705
Old 05-19-2009, 04:43 PM
ybonesteak's Avatar
Originally Posted by Cheapass
Look in to a new CDI and raising the carb jets a size or so.
what kinda of costs are we talking about for mods......
  #706
Old 07-14-2009, 11:57 AM
RonV's Avatar
A jet is about $4. A performance CDI is around $45. You can upgrade the CVT with different rollers/sliders and a torque spring for around $50 and that can make it climb really well. You need to get over to buggynews.com as that is where the best info is on these chinese buggies. This forum really has limited info.
  #707
Old 10-26-2010, 12:03 PM
MUDD DIGER1234567890's Avatar
Default broke
i have a twister 150 go kart and it will run but wont move it will roll thocan anyone help: huh:
  #708
Old 01-30-2011, 10:15 PM
gungus_mckee's Avatar
Default my hammerhead
HI im new here and my dad got me a new hammerhead, are they anygood or r they like a pocket bike ?
id like some feed back thanks
  #709
Old 01-30-2011, 10:18 PM
are the hammerhead 150s better then a atv ?
  #710
Old 01-30-2011, 10:20 PM
idk what a mahherhead 2 is but i have a hammerhead 150 and idk how good they are :s
Quick Reply: twister hammerhead 150cc go off road go kart
