jetting question for 400ex
Old 08-03-2004, 12:30 PM
blasterrider04's Avatar
Default jetting question for 400ex
i just got an 04 400ex last week and i ordered a pro circuit t-4 silencer uni air filter and outerwears air box cover wat jetting should i use.
Old 08-03-2004, 01:08 PM
Hondanutcase's Avatar
Whats the altitude where you live? You can experiment with different jets. With a pipe and filter you might go with a 153 - 155 main jet. They are very inexpensive.
Old 08-03-2004, 02:05 PM
reconbasher's Avatar
i live in mississippi and i run a 158 with 416kit
Old 08-03-2004, 06:41 PM
Ozark38's Avatar
I run a Pro Circuit s/o, Hotcams Stage 1, White Bros Powerfilter with an outerwears lid. My jetting is as follows; #40pj, needle clip in 4th slot, #158mj, air/fuel 2 turns.
I can run with a buddies stock 04 Predator til 4th gear on asphalt (but he's not real good with it yet)............[img]i/expressions/face-icon-small-wink.gif[/img]
Old 08-03-2004, 07:35 PM
Yo, Ozark! Getting off subject, but how does the power differ since you installed your HotCam. I just ordered a stage 1 and I am hoping for a little more mid range power.
Old 08-03-2004, 07:57 PM
Ozark38's Avatar
Its kinda hard to tell exactly cause I did all the mods at one time. The low end is really noticable. Hills I use to climb in second I now power up them in third. Holeshots (not the tires) are a big improvement. The front end comes up easier. There is more power in the mid range and the top end as well. I can hit the rev limiter a lot easier than before (didn't even knew it had one) [img]i/expressions/face-icon-small-smile.gif[/img] Well worth it IMO. [img]i/expressions/face-icon-small-wink.gif[/img]
Old 08-03-2004, 08:05 PM
mxer250's Avatar
Hey i just put a stage 1 hott cam in my 416. It picked up quite a bit. But im having trouble with jetting i ran a 162main and it boged in the mid range so i put in a 170 and it has no bog. By the way i run a ported head no lid air box full big gun race. It seems to run good should i try a 150 or something around there? P.S. i dont want to run it lean.
Old 08-03-2004, 08:08 PM
mxer250's Avatar
Hey ozark38 i put on a big gun rev box today still with my 170 main jet. And the rev box changes the power band and revs higher you can really notice it.
Old 08-03-2004, 08:22 PM
Ozark38's Avatar
Cool!............Though you'll probably need it more than I would with the 416. Mine is more set up for low and mid range. The only time I hit the rev limiter is when I'm drag racing and don't shift soon enough (no more power to be made). I mainly race on the trails and this is how I like my setup......(this is me....[img]i/expressions/face-icon-small-happy.gif[/img][img]i/expressions/face-icon-small-happy.gif[/img][img]i/expressions/face-icon-small-happy.gif[/img][img]i/expressions/face-icon-small-happy.gif[/img][img]i/expressions/face-icon-small-happy.gif[/img])
btw, have you changed to a bigger pilot jet and/or moved your needle clip?
Old 08-03-2004, 08:41 PM
Ozark38's Avatar
Btw, I'm still new to this jetting thing. Cals400ex is the jetting guru but I haven't seen him post in a while.
Quick Reply: jetting question for 400ex
