I need the timing settings for a Sundiro 90 (Eton or Polaris would probably work)
Old 11-08-2004, 10:03 PM
Hawkdriver's Avatar
Default I need the timing settings for a Sundiro 90 (Eton or Polaris would probably work)
This message is a new question but is a continuation of my post "Engine Trouble with Sundiro 90 - HELP!!!!"
A friend of my neighbor has looked at my sons ATV and concluded that the problem is the timing. It has fuel, compression, and spark - apparently just not in the right order.
Does anyone know the timing settings for a SUNDIRO 90cc 4wheeler? I assume the settings for an Eton or Polaris would work.
THANKS IN ADVANCE!!!
Old 11-09-2004, 10:23 AM
LT80's Avatar
LT80 Expert
To adjust the timing, you need to turn the stator plate. I don't think that your stator plate is made to turn. Meaning that the timing is set and not supposed to be touched.
I have a viper motor here and the there was no slots for adjustment of the stator plate. It should be the same motor basically.
I feel that your problem is somewheren else. Prolly more like a bad stator or coil.[img]i/expressions/face-icon-small-confused.gif[/img]
whitty
67
02-24-2021 02:52 PM
neilbedwell
11-10-2018 11:02 AM
brinkkl2000
06-11-2015 12:46 PM
Fnqrider
05-31-2015 08:29 AM
Steven Bandemer
05-27-2015 07:39 PM
Quick Reply: I need the timing settings for a Sundiro 90 (Eton or Polaris would probably work)
