Redcat/Kazuma fx150 trans
Old 01-22-2005, 10:53 PM
chubbysdad's Avatar
Default Redcat/Kazuma fx150 trans
Iam posting this for a friend. He has a redcat fx150. It has one of those auto trans which just has a shift lever on right with foward and reverse. It wont go into either now. It was very hard to shift but now wont shift at all. Anyone else have this problem? Any one have and ideas on what to look for?
thanks in advance.
Old 01-23-2005, 02:02 AM
notagain's Avatar
Sounds like the linkage is way out of whack. More info would be needed like how does it get ridden, age, etc. Do they perfrom reg maintenance? Probably a very simple issue once you look at it.
Old 01-23-2005, 09:43 AM
eigerclay's Avatar
We have a friend who has a kazuma 150 and he has problems shifting from reverse back to forward also, wonder how many people have this problem?
Old 01-23-2005, 09:52 AM
chubbysdad's Avatar
47 year old lady drives it believe it or not. Its only a month old. rides in orange groves.
Old 01-23-2005, 09:57 AM
95wolv's Avatar
Check out the new sponser, Raceway ATV, he is a dealer for Redcat, Kazuma and others, he should be able to help you, he is always on the forums telling everyone about the great deals, hope he has some tech knowledge, too.
Old 01-23-2005, 12:44 PM
doorguy's Avatar
I have read posts on these forums about similar problems. One rider found that rocking the bike back and forth while trying to move the shifter helped. My neighbor has a Yamaha 350 Raptor, and we found that it was difficult to move into and out of reverse also and rocking the bike helped.
Hope that helps.
Old 01-24-2005, 04:15 PM
tip28's Avatar
check the reverse gear box to make sure all the gears are still intact
Old 01-27-2005, 05:41 PM
TomDnSC's Avatar
If you decide to replace the Reverse Gearbox on a 150 yourself, I can give you a few tips.[img]i/expressions/face-icon-small-tongue.gif[/img][img]i/expressions/face-icon-small-confused.gif[/img]
Old 01-27-2005, 08:07 PM
chubbysdad's Avatar
ok great. What kind of tips are you talking about?
Old 01-27-2005, 11:08 PM
TomDnSC's Avatar
The first Reverse Transmission Assembly that I replaced, I removed the Racks, Fenders, and the Engine. Now I recommend removing the Left Foot Peg and the black plastic part of the rear fender in order to remove the Black Transmission Cover.
I maul the head on the M12 x 1.25 Flange Nut that holds the Belt Clutch in place. I use a Chain Wrench to hold the Belt Clutch while removing this nut. I replace the nut with an ARP M12 x 1.25 12 point Flange Nut. I bet everyone mauls the head on that nut trying to get it off. I have some Grade 8.8 non-serrated flange nuts on order but they will not arrive for another couple of weeks. The ARP nut cost about $5 EA. The only other nut I could find in stock was made of Titanium $$$$.
The Gearbox which is actually between the Transmission and the Reverse Transmission has its own oil drain and fill plugs. These are not mentioned in the manual. I fill the Gearbox with 8 oz of 80w-90 Gear Oil. The Reverse Transmission needs 16 oz of Gear Oil.
Quick Reply: Redcat/Kazuma fx150 trans
