honda 400ex 416 big bore kit
Old 03-03-2005, 09:14 PM
ModifydZ400's Avatar
Default honda 400ex 416 big bore kit
who makes the best 400ex 416 big bore kit? how much $?
Old 03-03-2005, 09:41 PM
orky4969's Avatar
good question
Old 03-03-2005, 10:29 PM
honda400rider's Avatar
Stop being lazy and look around the site.
Old 03-03-2005, 11:23 PM
orky4969's Avatar
we dont need an ħ§ hole comment from you, u dont wonna answer what some one is asking, which this site was set up for.. then dont.. just move along! [img]i/expressions/face-icon-small-mad.gif[/img]
Old 03-04-2005, 01:26 AM
Ds650RaCeR's Avatar
all 416 kits are pretty much the same..the wiseco kit is the same as the sparks kit,lrd,powroll,all of them are the same...some might use JE pistons some might use wiseco but all you do is bore out your stock cylinder for the 416..If you are wanting a big bore kit go ahead and get a 426 or 440 kit..you'll be happy either way...ne questions you can pm me..
Old 03-04-2005, 01:27 PM
khen's Avatar
I'm very pleased with my Wisco 11:1 416EX in combination with the HotCam Stage 2(now being labeled as the Stage 3). I purchased my bored cylinder, piston/rings and hotcam from a guy who never used them for $230. If you're buying them from a parts house you should be able to keep it all under $300 including boring out your cylinder.
In addition to the cam/416EX kit I would recommend buying a CDI that advances your timing and gives you a bit more rev. I wasn't sure if this would offer an improvment on mine or not until I put on a cheap one and it was quite noticable.
BTW, I also did my own port and polish work at the same time as my 416, so I don't know how much of my performance increase was related to the P&P but I suspect most of the gains were from the 416/cam.
XxS0ccerstarxX
10-18-2021 10:03 PM
Asaran
10-08-2015 11:14 AM
Huntingdeer
08-23-2015 12:06 AM
Espo720
Technical and How-To Articles
08-19-2015 02:44 PM
XxS0ccerstarxX
08-07-2015 06:18 PM
Quick Reply: honda 400ex 416 big bore kit
