Valve Lash (adjustment) on LT230 quadsport
Old 09-08-2005, 09:04 PM
ChewyR's Avatar
Default Valve Lash (adjustment) on LT230 quadsport
Does anybody know the proper lash specification for the LT230 engine. I don't have a manual, but I can see how to adjust it, I just need to know what the gap is supposed to be either hot or cold.
Old 09-08-2005, 09:51 PM
mxermann's Avatar
if you mean valve clearance when cold it is 0.001-0.003" for intake and 0.003-0.005" for exhaust valve.hope this helps.
Old 09-09-2005, 12:16 AM
ChewyR's Avatar
thanks, are you sure on that, it seems awful tight. Just want to make sure it's not .010-.030 and .030-.050 because that is closer to what auto engine is set at.
Old 09-09-2005, 07:57 PM
mxermann's Avatar
double checked the manual and that is what it says.be sure piston is tdc. later
donintennessee
01-08-2021 12:40 PM
Hankey Pankey
05-01-2018 01:33 PM
rawbdiggity
34
09-02-2015 02:16 AM
Hankey Pankey
08-17-2015 05:01 PM
NatePerz
07-27-2015 03:27 AM
Quick Reply: Valve Lash (adjustment) on LT230 quadsport
