Bayou 220
Old 09-28-2005, 02:25 AM
Rgibbs's Avatar
Default Bayou 220
I have a 94 Bayou 220. WHen you shift into gear it stalls. I have tried to turn the idle up with the idle up it will start to roll. What could be the problem? Thanks for any help.
Old 09-28-2005, 07:20 AM
justgo's Avatar
Default Bayou 220
Try adjust the valves ..
Old 09-28-2005, 08:58 PM
justgo's Avatar
Default Bayou 220
Maybe the plug is it gap..right,,,,Then i would look at the carb...the jets if u have any thing in one of them holes it will do that --2,,Just remove the 4..corner screws the main jets sit in the middle remove then and just make sure there are clean...if u hold them up in the light u can see right throw them.,..holes...then u no they are clean..good luck..
Old 09-28-2005, 11:16 PM
dgford8200's Avatar
Default Bayou 220
Good suggestions so far. Usually, if an engine stalls under load, it is in need of a tune up. Check the plug and air cleaner. If both are OK and the problem persists, a carburetor kit is likely needed...
Old 09-29-2005, 12:37 AM
bmj67's Avatar
Default Bayou 220
mine did the same thing. my idle was set perfect when i was in neutral then as soon as i put it in gear it jumped forward and stalled. it turned out to be the one way bearing in the primary clutch was bad. i put a new one in and it works awesome now.
wendal
10-31-2017 03:31 AM
Nosniborpapa
09-19-2015 07:07 PM
wendal
09-15-2015 01:50 PM
wendal
09-15-2015 01:48 PM
rcappie4
09-09-2015 07:04 PM
Quick Reply: Bayou 220
