Improved Sportsman headlight Bulbs
Old 10-06-2005, 06:18 PM
magna29's Avatar
Default Improved Sportsman headlight Bulbs
I remember reading a post about a better bulb for the sportsman headlights. After searching for a while I cant find it. Anybody know what it is? Seems they said you could even get the bulbs at walmart! TIA
Old 10-06-2005, 08:24 PM
Yes.......I think it was two days ago someone made a post soliciting on EBay for $1.00 instructions on where to go to buy 55watt low beam replacement bulbs which would then sell for $10.00 per bulb. I think the webmaster must have removed it because it was an obvious solicitation.
FYI.......I found replacement bulbs on the KIMPEX website. These are direct replacements for the Polaris Sportsman two front low beam bulbs. They have both 37.5 watt and 50 watt. These are GE units and the price is less than $10.00 each. I believe the stock ones are only 27 watt. Remember that more wattage means more heat......so when you replace them you should monitor initially very closely that they don't melt the stock housings.
Also FYI.......I removed one of mine previously and brought it to several auto parts stores AND Walmart. The guys at the auto parts stores didn't have a clue who made it or where to get it and WallyWorld didn't have it either.
Click the link below and then go to "ATV"......then go to "Winches and Electrical".......then go to "bulbs, lights".
Someday I'll get around to getting them myself.
Good Luck, Bob
www.kimpex.com
Old 10-06-2005, 08:33 PM
cornbread2's Avatar
The people in your auto parts stores are idiots. These bulbs are not made just for Polaris. They are automotive bulbs and the vast majority of auto parts stores have them. Our local WalMart stocks them.
The upper bulb is nothing but the exact same bulb that came out on almost every motorcycle made since about 1980.
They are also avalible at some auto parts stores and some WalMarts. The high power versions can be bought at almost any place that sells motorcycle stuff.
Old 10-06-2005, 09:50 PM
............and to think that I thought it was just the Politicians up here.
Old 10-06-2005, 09:55 PM
upnort's Avatar
http://www.bluhmenterprises.com/prod...hp?style=other
This company makes or sells lites that are supposed to be brighter than regular. I see them at snowmobile shows.
Old 10-08-2005, 08:06 PM
STSACER's Avatar
I wish Cornbread2 would take the time to investigate his incorrect information that these bulbs can be had at any parts store. Wrong!And I wish the people saying the GE 894 bulb works would notice it is a smaller housing with three tabs instead of four. The information on ebay is correct for these models. Not for any others !!
2005 ATP 500 4X4
2005 ATP 500 4X4
2001 DIESEL
2002 XPEDITION 325
2002 MAGNUM 325 4X4
2002 MAGNUM 325 4X4
2002 325 MAGNUM 4X4 HDS
2002 MAGNUM 325 4X4 FREEDOM
2004 A04CH68AU/CU SPORTSMAN 700
2002 SPORTSMAN 500 ALL OPTIONS
2002 SPORTSMAN 400
2002 SPORTSMAN 6X6
2002 INT'L BIG BOSS 6X6
2003 SPORTSMAN 600
2002 LUH 6X6 PPS
2004 A04CH42AQ SPORTSMAN 400
2004 A04CH50AQ SPORTSMAN 500
SERIES 10 PTV 4X4
2004 A04CH42AA SPORTSMAN 400
2004 A04CH50AA SPORTSMAN 500
2004 A04CH59AF SPORTSMAN 600
2004 A04CH68AC SPORTSMAN 700
2003 SPORTSMAN 6X6
2003 SPORTSMAN 700
2003 SPORTSMAN 500 HO
2003 500 MAGNUM 4X4 HDS
2004 A04CH68AK SPORTSMAN 700
2004 A04CH59AK SPORTSMAN 600
2002 SPORTSMAN 700
2002 ATV PRO 500 4X4 PPS
2003 SPORTSMAN 400
SERIES 10 PTV 6X6
2004 SPORTSMAN 6X6
2005 SPORTSMAN 6X6
2004 ATP 500 4X4
1998 XPLORER 300 W98CC28C BULB,H/L,27W.HOBBS
1998 SPORTSMAN 500 W98CH50A BULB,H/L,27W.HOBBS
1998 XPLORER 400L W98CC38C BULB,H/L,27W.HOBBS
1998 SPORTSMAN 500 W98CH50AC BULB,H/L,27W.HOBBS
1998 MAGNUM 4X4 W98AC42A BULB,H/L,27W.HOBBS
1997 SPORTSMAN 500
1997 MAGNUM 4X4
1997 SPORTSMAN 400L
1997 XPLORER 300
1997 BIG BOSS 6X6 400L
1997 SWEDISH MAGNUM 6X6
1997 MAGNUM 6X6
1997 XPLORER 400L
Old 10-09-2005, 12:43 AM
SportsmanEE's Avatar
Things to keep in mind when using higher than stock wattage bulbs:
* The headlight enclosures were validated with 27W bulbs. Higher wattage means more heat, which can lead to warping, melting and sealing issues with the headlight enclosures.
* The contacts in the handlebar headlight switch are rated for 10A. Two 50W low beam bulbs put you very close to 10A during low battery conditions.
* Increased bulb wattages can cause charging system deficiencies which can lead to a dead battery, especially if you spend extended periods of time at idle.
Old 10-09-2005, 03:16 PM
carpenter's Avatar
Sportsman EE is sooo right. i put new 55watt light on my sportsman ( bought them at walmart ,check out pics) i used a relay from radio shack so all the power was not going through the switch . but with the three headlight mod and the 55 watt lower lights it sucked the battery dead riding at night at little saraha
Old 10-10-2005, 09:42 AM
cornbread2's Avatar
I said the STOCK bulbs can be bought at any auto parts stores and the highpower power bulbs can sometimes be ordered at ANY auto parts store where the person behind the counter is not an idiot.
The lower bulbs are AUTOMOTIVE bulbs. They are used in many import and US made cars that come from the factory with fog lights.
I have personaly bought these bulbs at Walmart and parts stores many times for less than half what a Polaris dealer charges for them.
You are not the only sorce for such info.
Stop trying to sell us your BS.
We are capable of living without you.
Old 10-10-2005, 09:45 AM
cornbread2's Avatar
A Polaris will eaisly pull two 55 watt bulbs and keep the battery well charged. It will not pull three 55 watt lights unless you are running at a very high RPM at all times.
Quick Reply: Improved Sportsman headlight Bulbs
