05 Brute Force 650 question
Old 10-10-2005, 12:25 PM
DJW's Avatar
DJW
DJW is offline
Default 05 Brute Force 650 question
I was running down the road at full speed, and the engine started breaking up. I looked behind me to see a cloud of white smoke. The engine stalled, I restarted and smoke is puring out of the exhaust. After a few minutes, it cleared up. It has been running fine every since. Any ideas of what could have caused this? Thanks for any feedback.
Old 10-10-2005, 12:34 PM
95wolv's Avatar
Check your antifreeze, a big white cloud sounds like coolant got sucked in from the head gasket, possible that a small leak got some in the combustion chamber and came out the pipe. Also, it is possible a high speed run could have pressurized the sump and forced some oil out the breather into the air box, sucking it into the carb and burning, check the air box for any oil in it, if you overfill after an oil change, this can happen. If it is running fine now, I am leaning more towards the extra oil in the box, but check both to be safe.
Old 10-10-2005, 01:16 PM
newbeatle's Avatar
most likely it was oil in your filterbox... it comes in there throught the crankcase vent line, & can be splashed up there from extended WOT runs, or if the oil is too full... when filling the oil, always fill it to 1/2 way between the add & full marks... if it is filled to the maximum when cold, it will often pump oil into the filterbox at high rpm, after warmed up...
Old 10-10-2005, 01:48 PM
rivermud's Avatar
most likely it was oil in your filterbox....>>>> I agree [img]i/expressions/face-icon-small-wink.gif[/img]
Old 10-10-2005, 04:31 PM
sammydogs64's Avatar
OIL OIL OIL, Level should be below full mark for normal use
Old 10-10-2005, 08:52 PM
DJW's Avatar
DJW
DJW is offline
Thanks to all that responded.
Pgbama11
01-16-2016 08:19 AM
ylomnstr
09-22-2015 12:19 AM
Pgbama11
09-10-2015 08:20 AM
ylomnstr
09-10-2015 06:45 AM
ylomnstr
09-04-2015 05:02 PM
Quick Reply: 05 Brute Force 650 question
