King Quad Valve Clearance Question
Old 12-09-2005, 12:36 AM
56Nomad's Avatar
Default King Quad Valve Clearance Question
This is a gear head question............
I'm doing my 100 mile service and checked the valves. A lot
of plastic had to come off to remove the cylinder head cover.
The Manual Valve Clearance Specs call for:
Intake: (.004 - .008 inches)
Exhaust (.008 - .012 inches)
My intakes are .003
My exhausts are .008
Any problems with the intakes being .001 below specs (tighter)?
Old 12-09-2005, 12:49 AM
IdahoVinnie's Avatar
Yes.
A loose valve will make a little noise.
A tight valve runs the risk of burning the valve. It may not fully allow enough exhaust gasses out of the cylender.
One way to look at it is that you are only adjusted to 75% of minimum specs. Also, as long as you have it disassembled that far, a screwdriver and a wrench is all that it takes to have it properly adjusted.
Do the specs "Intake: (.004 - .008 inches)" mean that .004" is the cold setting, and .008" is a hot setting? Or should it be set anywhere from .004" to .008"when cold?
Old 12-09-2005, 01:01 AM
Hemi4u2nv's Avatar
My service manual says specs should be used when cold. So .004-.008 is the tolerance when cold. Since you have it torn down, you might as well put it in spec.
Old 12-09-2005, 02:01 AM
56Nomad's Avatar
Thanks for your replies IdahoVinnie and Hemi4u2nv.
So indeed I have the valve cover off, but I don't see a way to
adjust the valves with a wrench and screw driver.
It looks like I have to remove the cam to do any valve adjusting by
replacing the shims after the cam is removed.
I'm thinking that I'm close enough for "government standards" What do
you think?
Old 12-09-2005, 11:33 AM
Hemi4u2nv's Avatar
So they don't look like this?
pic 1
I used a leatherman and a box-end wrench to adjust mine.... but the KQ is probably a much more sophisticated beast.
Old 12-09-2005, 01:33 PM
56Nomad's Avatar
I sure wish mine were that easy [img]i/expressions/face-icon-small-frown.gif[/img]
My intakes being .001 below specs at only 100 miles will probably open up to specs with use....I hope
Click here to show KQ valve adjustment
Old 12-09-2005, 02:19 PM
Daniel631's Avatar
Your valves will only get tighter. The reason they tighten up is because of valve seat and valve face wear. After a while the valve will not close all the way and your bike will become really hard to start. Measure the clearance with the piston at TDCC. If they are tight you need a smaller shim. Use the number on the shim and the clearance you need and do the math. Try to get the valves in mid spec range. All valve measurements and adjustments are done cold.
If you don't have a manual or know how to set the cam timing get a manual before you tear the cam out.
Old 12-10-2005, 12:27 AM
56Nomad's Avatar
Thanks for all the advice. I went ahead and pulled the camshaft on the intake and will
be putting in a smaller shim to achieve spec.
hugemoth
07-20-2020 03:28 AM
Frisky2050
04-09-2020 11:19 AM
toonces
10-16-2019 12:11 PM
tweeder
07-05-2015 01:57 PM
D-Hagz
07-04-2015 02:19 AM
Quick Reply: King Quad Valve Clearance Question
