kazuma 110 transmission oil
Hi,
We just got a Kazuma 110 on Friday.
On one side there is a chrome dipstick (uh with no dipstick) where the engine oil goes in. Then you watch the site glass. Got that part figured out.
But before that I put motor oil in under a chrome cap that had a slot in it. On the top left side of the transmission.
1. Where did I just put motor oil at? *IS* that the transmission?
2. Can I use motor oil in there?
3. If not what to do then?
Please help.
Please help.
the chrome one with the slot on the left side of the engine is to look at timing marks on the flywheel, not oil. the oil fill hole is on the right side towards the rear where the dip stick is or was, the oil lubes both the transmission, clutch and engine thats why it very importance to keep the oil change.
I put oil into the flywheel side then!
how do I drain that out? take the side cover off?
thanks for your help thus far...
I know my V-force 700 inside and out but am struggling a little with this bike. And the <cough> Kazuma manual with all the pictures isn't very helpful... argh.
yep, going to hafta remove the cover, wipe it out the best you can
He said it will dry out and be fine, but I like your advice too, should only take a little bit to clean that out.
thank you.
Jeff Roper
02-01-2022 11:48 AM
