bf 750 trouble
Old 04-18-2006, 10:57 PM
27vamps's Avatar
Default bf 750 trouble
i got an 06 750 an at an idle an low speeds it has pop but when u get it up to bout 1/4 throttle it clears up an runs fine any suggestions?
Old 04-19-2006, 11:06 AM
Kawi650's Avatar
dirty plugs
Old 04-19-2006, 09:00 PM
27vamps's Avatar
ok thanks ill try that an see what that does
Old 04-19-2006, 09:12 PM
stendori's Avatar
I'm watching you!
my bud has an 05 bf 750 and it back fires when you let off the throttle so slow down. do these run lean does anyone know?
Old 04-20-2006, 01:35 AM
bruteforcebob's Avatar
just guessing, but are you running a dyna igniton?
Old 04-21-2006, 02:51 PM
27vamps's Avatar
no not at the moment but had a dyna cdi on there but took it off cause it was running real lean an it really hasnt ran good since i took it off
Old 04-21-2006, 03:53 PM
Hayashi's Avatar
For backfiring during deceleration, make sure your choke cable plungers on the carbs are closing ALL THE WAY when you turn off the choke (lever pushed all the way to the right). Slightly open choke plungers will let extra fuel into the carb. You have to "watch" each plunger as you (or your buddy) are pushing the lever. The plungers may get hung up due to the corrosion forming between the disimilar metals - brass plunger in the aluminum bore. Take them out and give a really good wipe with steel wool and spray some white lithim grease. Choke cable routing is important as well so that it doesn't bind or get pinched causing the plungers not to close all the way.
Old 04-22-2006, 03:02 PM
27vamps's Avatar
yea i didnt even think about the choke hangen up on it ill have to check that out an see if thats it
Old 04-29-2006, 09:45 PM
sam's Avatar
sam
sam is offline
its the needles there lean. they did a upgrade on the needle from the first ones out. mine did that in fact alot do. mine even had the newer needle and still did it. I put a dyno jet kit in and problem all gone.
you might want to check over at kawieriders, this topic has been talked about alot in the past.
sam
Old 04-30-2006, 06:33 PM
brokebrute's Avatar
Sounds to me like you need to adjust your air/fuel screws. You have to take the carbs off to adjust them but it helped mine turn them all the way in then back out 2 1/2 turns.
Quick Reply: bf 750 trouble
