LTR 450 Suspension
Old 04-22-2006, 01:11 PM
stinger's Avatar
Default LTR 450 Suspension
Not sure where I should be set up on my shocks. Only weigh about 140-150 lbs. and stand at a short 5.5. Any suggestions.
06 LT-R 450 (New)
Yoshi Full System Exhaust
K&N Air Filter
Lidless
Yoshi Cherry Bomb
Re-geared (1 tooth down on front sprocket)
03 Z400 (Old)
K&N Air Filter
Dyna FX Programmer
Re-geared ( 1 tooth down on front sprocket)
Old 04-22-2006, 04:20 PM
quadfam4's Avatar
Before I rode it the first time I started by backing off the front springs 4 turns and the rears 3, no sag stock setting. Backed off the comp and rebound dampning a couple clicks. Have over 40 hrs on it and haven't touched it since. Other people that have ridden it says it feels fine. I like it right where it is.
Old 04-23-2006, 07:18 PM
Raptor149's Avatar
it depends upon the riding you plan on doing. motocross? trails? dunes? being that you are so small, you can probably soften it up, as the shocks are stiffer from the factory because they are setup for a motocross track.
why did you drop the front tooth even with the addition of the Yoshi cherry bomb?
Robinhood
12-26-2015 10:28 AM
bigred20653
09-19-2015 02:11 PM
chewy78
09-08-2015 10:37 AM
Nekolai1
08-25-2015 10:04 PM
Mssarabug
08-10-2015 12:56 PM
Quick Reply: LTR 450 Suspension
