Lt250r Differences between 87-88
Old 05-30-2006, 05:11 PM
RappinErnie's Avatar
Default Lt250r Differences between 87-88
Are the 87 and 88 quadracers basicly the same? If they are different, what are the pros and cons of each, and are the parts interchangable? Thanks.
Old 05-31-2006, 11:23 AM
f250r's Avatar
http://www.geocities.com/kiwi_craig/LTengdata.htm go here it will explain. 87s way better the intake reed cage is alot bigger, i have one, take and put an 88 head on it and a quadzilla intake boot to fit on 39mm kehin carb its a nasty setup
Old 05-31-2006, 07:45 PM
Hey if that works good then I'm in businus. The Lt's I may be buying are a package deal, there is an 87', and an 88'. The 88' doesnt run. If I took the head off the 88' and put it on the 87', would a Paul Turner pipe from the 87' fit on the 88's head? And what about frame wise? Would the fenders from an 88' fit on an 87'? Thanks.
Old 05-31-2006, 07:46 PM
And by the way, your Lt is sick, I want to do the same exact thing, just with different colors.
Old 05-31-2006, 08:20 PM
f250r's Avatar
thanks, 87 and up pipes will fit all models except 85,86. make sure if u run the combo im doing u use oem headgaskets there the only one thats worked for me im runnin i think 180psi comp. the PT pipe is the way to go there the best in my opion get the low end one. the frames change on 90 and up years
Old 05-31-2006, 10:02 PM
sblt500r's Avatar
differances in the engines,
heads are different. the 87's have a different dome
intakes are different, 5 bolt instead of the smaller 6.
counter balancers are different. the 87 uses a larger seal than the 88-92.
87 pistons are diferent. year specific pistons because of the different cylinder porting.
frames
frames are basically all the same except for the 91-92 which have a different rear shock and swingarm set up, and a different air box.
the rear axles are diferent on the 87, only because they have a different spline count. the 87 has a 24 spline just like the 85-86. the 88-92 have 26 splines, which is the same as the lt500r, and the z400.
all the fenders swap from 85-92. just that the seats on the 85-86 are different but the fenders still work fine.
Old 05-31-2006, 11:50 PM
Sweet, thanks. I don't really want to wind up screwin one of the Lt's up, so I might just fix em both up and use one for parts, or for a friend. The Paul Turner pipe I was talkin about is already on the 87' bike so I don't know if its low end, but I hope it is, because i never really go above 40 around hear, and I love doin wheelies and spinnin the back tires. Thanks for all the info guys, it really helped. Hopefully I will sell my ATV and gokart this friday so I can pick up the Quadracers. Thanks again.
Old 06-01-2006, 02:00 AM
Bastosako's Avatar
hey ernie, whenever you're finished could you spare a frame? i'd pay shipping of course [img]i/expressions/face-icon-small-wink.gif[/img]
Old 06-01-2006, 06:30 PM
Sorry dude, but the whole point of me buying two was to have extra parts or if I can get em both workin, use em both. But you can get Quadracer frames for real cheap on ebay. I have seen decent ones go for 50 bucks. Sorry.
Old 06-01-2006, 06:42 PM
Here is one that is currently up for bid.
http://cgi.ebay.com/ebaymotors/87-92...QQcmdZViewItem
Johnny Mac
08-15-2019 03:13 PM
fredrikrosen
09-28-2015 09:58 PM
Levi Enstad
09-26-2015 08:00 AM
MikeyBoyesq
09-22-2015 10:02 AM
Halffast17
09-11-2015 02:30 PM
Quick Reply: Lt250r Differences between 87-88
