Gorilla 3000# Winch Wiring - Lost Instructions
Old 07-08-2006, 11:26 PM
oldsmoboat's Avatar
Default Gorilla 3000# Winch Wiring - Lost Instructions
Anyone still have the diagram from the instructions?
What goes where on the solenoid? The + and - on my 05 SP 400 are bonded or attached together. The don't seem to line up with anything.
Also, which terminal does the red wire from the switch go to?
TIA
Found it
Wiring
Old 07-09-2006, 08:02 AM
stendori's Avatar
I'm watching you!
sounds like your trying to use the prewired set up on your machine. i dont know if it will work or not. the red wire is to go to a hot wire on the wheeler to give the solenoid power. the other one should plug in to the black box(soleniod). if i remeber right the cables that come w/ the gorilla are color coded to the term. on the black box. i installed my buddys on his bf 750.
Old 07-09-2006, 10:35 AM
2manytoys's Avatar
The red wire from the switch goes to any live hot wire.
Old 07-09-2006, 04:09 PM
oldsmoboat's Avatar
Thanks.
Yes, I want to use the + and - that Polaris already has in place instead of running more wire back to the battery.
Old 07-09-2006, 05:53 PM
oldsmoboat's Avatar
Wiring
Old 07-09-2006, 11:50 PM
okietj1's Avatar
i had to cut the molded part apart to make it work i used pvc cutters and cut right through the center long ways through it. all worked perfect. i found an article somewhere on internet that showed really good pics of it but now i cant find it anywhere. hope this helps
Old 07-10-2006, 12:20 AM
oldsmoboat's Avatar
Good point, I had to cut mine too. I also had to extend the negative cable of the set to route the wire better.
jeepwheelin02
07-18-2020 06:42 PM
toonces
10-19-2015 02:21 AM
Bratman2
07-23-2015 12:36 PM
toonces
07-11-2015 12:01 PM
cornermike
07-08-2015 11:44 PM
Quick Reply: Gorilla 3000# Winch Wiring - Lost Instructions
