lt50 needle position
Old 10-04-2006, 03:46 PM
MINIQUAD97's Avatar
Default lt50 needle position
thanks if i drill holes into air box will i need to rejet or can i ajust rich enough and can i put a after market filter with stock pipe?
Old 10-04-2006, 04:10 PM
bulldogfallon's Avatar
I am fairly confident that you would need to rejet...The little carbs are very sensitive to airflow.....
  #13
Old 05-15-2013, 09:51 PM
johnk26's Avatar
Default wheel spacers
Where did you get the wheel spacers for the kfx 50? I have been trying to find some for my kid's 2005. Also what kind of wheels and tires should I run along with what size. We race in the woods.
  #14
Old 05-16-2013, 08:04 AM
LT80's Avatar
LT80 Expert
Welcome to the forums.
Maybe if you'd start your own thread.
This thread is 7 years old and is about a carb needle.
If you're looking for ground clearance, I doubt you'll be able to go any bigger on tires with that machine.
  #15
Old 05-16-2013, 10:49 PM
johnk26's Avatar
Default kfx50
I realize the post is old and about carb needle but there was a lot of other good info also. This was the closest thread I found to what I was looking for. I did post a new thread hoping for some info. I am not as worried about ground clearance as I am stability and keeping my kid out of the ruts from the wider atvs.
Dammar
04-20-2016 06:03 AM
wrencher82
09-24-2015 03:39 PM
Nosniborpapa
09-12-2015 05:54 PM
Hw00d
09-10-2015 08:53 AM
MikeyBoyesq
09-07-2015 10:44 PM
Quick Reply: lt50 needle position
