Rincon Clutch slipping
Old 10-30-2006, 04:11 PM
mathews's Avatar
Default Rincon Clutch slipping
My 2003 rincon is slipping in high gear , is this something that can be adjusted or how hard is it to replace? Does anyone have a blown-up diagram of the clutch assembly?if you do please email to my email address
gathabell@bellsouth.net
thanks
Old 10-30-2006, 08:26 PM
cluby's Avatar
how do you know that your clutch is slipping? what kinda oil are you running?
Old 10-31-2006, 12:22 AM
Rinman's Avatar
It sounds like your a little low on oil. The Rincon doesn't have a clutch. Also since its an 03 model you might have to have the o-rings in the trans replaced. This was a common problem on the 03's and early 04's. You should checkout rinconriders.com for more info on this problem.
Old 10-31-2006, 09:51 AM
reconranger's Avatar
Red Rider
Honda, accept nothing less!
One of the magazines suggested that this machine needs frequent oil changes. The tranny runs hot under heavy loads, and toasts the oil. Classic symptom is a slipping trans.............
What oil you using and when did you change it last??????
Old 01-31-2007, 07:44 PM
TheOneAndOnlyRedBear's Avatar
mathews
The Rincon doesn't have a clutch, but a torque converter like in a car. Sounds like you might be low on oil. The engine oil also work in the tranny. If you are low in engine oil, the tranny will be the first to let you know. Check it out first
It also may be the O rings that are causing you trouble. Does it seem like it won't shift in 3 as it should, like 3 gear isn't working. If so it's the valve O rings in the tranny. Honda had a recall on this problem and changed them during the 04 production. Mine had this problem and were replaced at no charge from the dealer.
Red Bear
[img]i/expressions/face-icon-small-happy.gif[/img]
Old 02-02-2007, 02:04 PM
1988TRX250R's Avatar
There was no recall issued for this. Yes there were more than a couple machines that had this problem and Honda is aware of it. However no recall was ever issued but most dealers are aware to check the o-rings if there are shifting and torque converter problems. Recall are issued for safety related problems, not for torn o-ring inside the engine.
Old 02-02-2007, 07:19 PM
Yes, your correct, it was a service bulletin that was informing the dealers of the problem and what to check for.
Old 08-27-2018, 09:38 PM
Dane Tibbetts's Avatar
Default Clutch slipping
Rincons do have clutches three of them one for each gear. If it didn’t have clutches then why would it call for oil that’s designed for wet clutches
Jeff Roper
02-01-2022 11:48 AM
buddieboy
12-09-2016 05:50 PM
tysonbully
09-28-2015 02:30 AM
XxS0ccerstarxX
09-24-2015 05:38 PM
jbrewster94
09-23-2015 04:16 PM
Quick Reply: Rincon Clutch slipping
