z400 timing
Old 10-31-2006, 10:12 PM
oldogg's Avatar
Default z400 timing
I have a z400 2004 model. I need to know how to set the valve timing. Which way do the lobes point when its on top dead center.
Old 11-01-2006, 09:59 PM
mucky's Avatar
Default z400 timing
THIS IS FOR TIMING STOCK CAMS 1..Remove the plug on the generator rotor, make sure the T line is in the center.,with the T line in the center hold the exhaust camshaft steady and lightly pull up on the cam chain to remove the slack between the cam chain drive sprocket and the exhaust camshaft sprocket. 2.. the exhaust camshaft sprocket has an arrow marked "1". turn the camshaft so that the arrow is aligned with the gasket surface of the head. engage the exhaust camshaft sprocket. 3..the other arrow marked 2 should now be pointing straight up. starting with the cam chain roller pin directly above the #2 count out 15 pins toward the intake and engage the intake cam on the arrow marked #3 on the intake sprocket, after its all on install the chain tensioner and turn the motor over 2-4 times and recheck your markings, if all marks line up then its in time.
Old 11-02-2006, 05:48 PM
witti's Avatar
Default z400 timing
Lobes will be ~10 and ~2 O-clock. Pointing away from the center of the cyll.
slowgsxr97
03-18-2022 03:40 AM
Sjrpp
06-02-2019 07:25 AM
95wolv
07-17-2015 08:13 PM
07-15-2015 02:07 AM
yambam13
07-04-2015 01:49 PM
Quick Reply: z400 timing
