Dr Lang - What did you glue loose flywheel magnets with ?
Old 12-28-2006, 11:22 PM
RickRitter's Avatar
Default Dr Lang - What did you glue loose flywheel magnets with ?
Hey Doc ~ I remember you had loose magnets once , how did you fix it and did it work ??
Rick Ritter
Old 12-29-2006, 08:50 PM
drlang's Avatar
I used a dremel tool to remove all of the old material. Then used a 2 part epoxy to re-adhere the magnet to the flywheel. The epoxy used was actually intended for anchoring to block walls. It's all I had in hand so I used it. It has been tested to 7000 rpm's. Doc
Old 12-29-2006, 09:12 PM
SherpaT350's Avatar
Did you mark the magnets when you took them off so, you got them back in the same place ? I thought about putting scribe marks to make sure they are in the same place.
So, you are still running the same machine with the magnets that you repaired ?
Thanks,
D.
Old 12-29-2006, 09:24 PM
drlang's Avatar
Oh yeah, that is the machine in my bio. The pipe shuts off at around 7000 rpm's, or I'd run it higher. I use that machine for drag racing only, I see your dealing with Rick, good choice. Yes you need to get the magnet in the right spot, mark or whatever you can. Darn I guess I won't be getting that 400 from you. I'll find 1 to build hopefully soon. PS if this engine build gets to much, remember me, I'll come and get it. Thanks Doc
Old 01-01-2007, 10:34 PM
STARKSREBEL's Avatar
i had the same problem with my 500 and used industrial strenth liquid steel.it worked great.
Old 01-01-2007, 11:13 PM
SherpaT350's Avatar
DR.,
I see in your Bio that you are using premix . That is the way I am going to go . Can I just make a blockoff plate and gasket or did you actually stick a plug into the hole that the oilpump shaft went into ? I am a Journeyman tool and diemaker by trade so making whatever I need is not a problem.
Thanks,
D.
Old 01-02-2007, 10:52 PM
drlang's Avatar
You'll need to buy the kit, not that you can't make the stuff. It's that the measurements aren't available. FYI my brother is also a tool maker and does whatever work for me I can get the specs for. Doc
Old 01-03-2007, 12:13 AM
SherpaT350's Avatar
Why can't you just make a flat blockoff plate that goes where the oilpump housing originally was located ? It looks like to me it would just be a 2.875X3.000 flate plate with three bolt holes tranferred from the oil pump casting housing.
Then at the carb. just plug the oil fitting.
Looks pretty simple to me but am I missing something ?
Thanks,
D.
chingchangchong
08-07-2022 11:36 AM
Joe454
11-20-2020 01:19 PM
Scooter's Shop
23
10-22-2015 07:04 PM
Scooter's Shop
10-09-2015 02:09 PM
MeadowlarkFarm
09-09-2015 03:08 AM
Quick Reply: Dr Lang - What did you glue loose flywheel magnets with ?
