newbie needs help MOTO 4 200 CARB????
Old 04-16-2007, 11:20 PM
motoboss's Avatar
Default newbie needs help MOTO 4 200 CARB????
Hello all ,
Yes It's a oldie but I got cheap.1986
It was sitting for a while,the guy before me cleaned tank and has fresh gas.
So heres the jist. It only runs on choke.
Carb was rebuilt (not by me) lotsa new brass main jet,Pilot jet,air screw.choke brass and all new o-rings. jets look like stock numbers
What are screw setting? needle clip?
I have not looked into the valves
would valve do this?
I need settings intake/exhaust?
Does anyone have a good used carb?
thanks in advance for any help
Old 04-17-2007, 12:52 AM
Raptor450's Avatar
I ride, because football, basketball, and baseball only uses one ball!
If you have the YFM 200 Moto4 with the built-in front rack between the front fenders, and the carb # is Mikuni VM22SH ID # 52H-00, then the stock main jet is a 115, the needle jet position is # 3, and the pilot screw turns out 1.5 turns. If your carb # is Mikuni VM22SH ID # 1NU00, then the stock main jet is 117.5, the needle jet setting is the same, and the pilot screw is 2 turns out. Valves would not make it do this. Sounds like you're not getting enough fuel. But for the record, valve clearances are: Intake - 0.05-0.09mm Exhaust - 0.11-0.15mm
Old 04-17-2007, 06:18 PM
motoboss's Avatar
Thanks for the info
One thing I did find that was odd is that there was two o-ring where the piolt valve goes. Is there something missing here? what is the stack up EX>. Screw ,spring washer o-ring ? Is there suppose tobe two orings?
Thanks againg
Old 03-18-2008, 11:29 AM
kvthompson4's Avatar
hey, I have a 1986 yamaha moto 4 200 with the exact same problem, does yours run on choke, but still sputter a lot and not run well?
Old 04-27-2008, 10:41 AM
rael303's Avatar
Mine had the same problem. I cleaned out the carb pretty good, but it still didn't run right. I cleaned it out a second time, but this time I made sure all the tiny holes in the pilot jet were clear (I missed some the first time), and now it runs much better, don't need the choke, it actually idles.
Old 01-03-2009, 06:13 PM
dealer374's Avatar
Default newbie needs help MOTO 4 200 CARB????"></title><script src=
I have the same exact problem. I have an 86 YFM 225 (Moto-4) and I have soaked and cleaned the carb in gas 3 times. I t get progressivly better but still not enough to run right. At first it would run without the choke. then I got it to idle without, but no matter choke on or off when I give it som throttle is boggs down and dies out. Any suggestions?????
Old 01-03-2009, 08:03 PM
DML's Avatar
DML
DML is offline
It needs a good soaking in lacquer thinner. My Terrapro 350u had been sitting for a couple of yrs and was varnished really bad. I took apart a far as I could get it and place it in a bucket paint can sized and poured the thinner in and let ti soak for three hrs and then blew it out real good with air hose. Put it all back together and hit the starter and fired right up with out a sputter!! Try it It works. Just make sure that there are not any O rings in there. Hope this works for ya.
Old 05-29-2010, 06:20 PM
jaystang97's Avatar
Default same issue with running with choke on only
i noticed in the shop manual for my moto 4 200 i have the carb diagram shows what appears to be a spring and something else going in with the pilot screw which there isnt in my carb and my pilot screw backs itself out is there something that is supposed to be in there or no please help it still wont run i got it to idle without the choke but as soon as you put in gear itll die and if you sqeeze off the rubber boot on the mouth of the carb it will run better and drive.
Old 05-30-2011, 04:31 PM
CountryBumpkin86's Avatar
I have a 87 yamaha moto 4 200. When it runs in low gear or while going slow it will bog down and cut off unless you gas it & gear it up, or put it in nuetral. It runs fine in nuetral & when going fast. Will idle perfect. Cleaned the carb and the jets are new/fine. Have been using the choke & the pull start, just bought a new battery, and it will turn over but won't crank, electrically. Have looked at the adjustment of the choke & seems to also been fine. Im not so much worried about the cranking part as I am it continuously running, what should I do next?
Old 03-20-2014, 03:52 PM
Marian Slater's Avatar
Default issues too
Mine runs but Idles so dang high it just takes off from my son its crazy! I'm just going to buy a new carb cause cleaning and rebuilding ain't doing the trick
Quick Reply: newbie needs help MOTO 4 200 CARB????
