what does a rectifier do?????
Old 04-17-2007, 03:35 AM
steve2432's Avatar
Default what does a rectifier do?????
I have an idea what a rectifier does, but I am not 100% sure. So I am asking what a rectifier does because I am only getting 12.5 volts when running and I need some more volts, so I need to know if I need a new one or how I can check if its good.
Old 04-17-2007, 07:52 AM
upnort's Avatar
A rectifier "rectifies AC voltage from the stator to DC. The voltage regulator regulates the DC voltage to proper level. At idle you will not be getting full voltage. Should rev it up to at least 2,000 rpms. Each machine has a certain spec but should get up over 14 volts at rated rpm. 12.5 is about normal at idle. Many of machines now have both in 1 module.
https://atvconnection.com/Department...ng-Systems.cfm
Old 04-17-2007, 11:03 AM
AZSAND's Avatar
THAT!!!!!Sounds down right sexy!
Very good answer and an exellent artical i guess im going to have to explore the connection a tad more i was uaware that it housed usefull info elsewhere.Intresting
Joe454
11-20-2020 01:19 PM
handyjc1
ATC 3-Wheelers
10-23-2015 07:15 PM
MATT BOOTH
Technical and How-To Articles
09-22-2015 08:35 PM
Nosniborpapa
09-19-2015 07:07 PM
johnny1982
09-13-2015 07:41 PM
Quick Reply: what does a rectifier do?????
