Carb Jetting for High Altitude
Old 05-11-2007, 02:07 PM
Octopus's Avatar
Default Carb Jetting for High Altitude
I have a 2007 Can am Outlander 400 Max. I live in Phoenix, AZ with an elevation of 1200 ft. I am going to Ouray CO for several days to ride in elevations ranging from 8000 to 13000 ft. Is it a must to re-jet the carb? I would prefer not to, but I don't want to get there and find out the my ATV won't run. I have a Mikuni BSR33 carb with a main jet size of 133.7. What should I do?
Old 05-11-2007, 04:21 PM
OhHell's Avatar
With that much of an elevation change it is going to be really rich if you dont rejet.
Old 05-11-2007, 04:35 PM
Octopus's Avatar
Thanks for the response, I am seriously considering Dial-a-Jet. Sounds like a great one time modification with great reviews.
Old 05-11-2007, 10:27 PM
reconranger's Avatar
Red Rider
Honda, accept nothing less!
My typical mountain ride starts in the valley at about 4,000', and can go up to nearly 12,000'....all in one day's ride! I also have places where I ride that are below sea level, so I have kept stock jetting. You can rejet by decreasing the fuel, or by increasing the air.....
On a carburated quad, I install as many Thunder Products TPI Valves as I can in the airbox lid (from the same folks who make the Dial-a-Jet by the way). As I ascend, I open them up gradually for more air intake. As I descend, I close them gradually so I won't be running lean (lean can damage an engine!). Above about 9,000" I just pull the airbox lid off completely. This is a system that works very well! It's the easy solution for those of us who ride big altitude changes....and costs almost nothing.
http://www.thunderproducts.com/tpi_valve.htm
Old 05-11-2007, 10:33 PM
Red Rider
Only disadvantage....you do have to be carefull on deep water crossings, to not get water over the level of the airbox lid.
Or.....get the new fuel injected Rancher 420!
Old 05-13-2007, 11:02 AM
Octopus's Avatar
Good input, thanks. I ordered the TPI valve as well. Hopefully the combination will help
Old 05-13-2007, 11:05 AM
Octopus's Avatar
This is my first quad, if I would have known the issues sourounding the carb and altitude, I would have bought the 500 EFI model.
Old 05-15-2007, 01:24 AM
Doctorturbo's Avatar
GOT BOOST!
No matter what you do or buy your going to loose a ton of HP at 13K. Not much air at 13K!!!!
cSchwartz
07-09-2015 02:43 PM
Robbbb55
CAN-AM (BRP) Ask an Expert!
07-08-2015 02:16 PM
Robbbb55
07-08-2015 02:11 PM
MNatv89
07-07-2015 11:36 AM
Quick Reply: Carb Jetting for High Altitude
