How to identify yamaha 4 wheeler?
Old 06-17-2007, 07:56 PM
myjunker's Avatar
Default How to identify yamaha 4 wheeler?
I have an older yamaha 2wd, mudflap says moto4 on it. Engine says 1500cm3 on it. Where might a look to find an ID plate or tag to determine year and model?
Thanks.
Also, in determining engine size... what is the 1500cm3, I'm assuming that means centimeters cubed???
Thanks again.
Old 06-17-2007, 09:30 PM
rruser's Avatar
I'm guessing you are looking by the dipstick? That number is telling you how much oil the motor takes. 1500cc is 1.6 quarts. The motor size would be at the base of the cylinder. I'm guessing it will be in the 210-230 range. As for the ID, it would be stamped into the motor and on the frame. The ID/VIN is always stamped onto the block itself (not side covers) in a place that is easy to read. It would not be hiding under the frame or anything. Look for a flat area on the right side, top, near the rear. The motor might have been painted a few times so look closely
Old 06-17-2007, 10:53 PM
Raptor450's Avatar
I ride, because football, basketball, and baseball only uses one ball!
Its probably an '86-'88 YFM Moto 4 200. If you cant find the numbers, tell us a description about it and what color it is, we could pretty much narrow it down. Back in the day, you could only buy one color for that year model, so unless someone changed plastics you can tell what year it is that way.
Old 05-05-2013, 05:08 PM
Country boy's Avatar
Yes I have a 1987 red moto 4 and we need to find out the motor size so we can buy a new piston for it .. Are friend gave it to us so contact me at 1270-871-7244 thank u and I would like to know ASAP
bigred20653
08-31-2015 12:41 PM
08-21-2015 01:23 PM
stendori
08-14-2015 12:57 PM
mdigitale
08-06-2015 12:35 AM
07-07-2015 11:00 PM
Quick Reply: How to identify yamaha 4 wheeler?
