2000 ds650 ignition problem still!!!!!
Old 06-22-2007, 12:46 PM
Mitch101's Avatar
Default 2000 ds650 ignition problem still!!!!!
well ive been working on my ds for a few months now trying to figure out whats wrong with it . well a few months back i was riding around and then it suddenly died on me to never start again . at first i tought it was the cdi because we checked all the fuses and there all good . so i went and bought a new cdi, and still no spark . so then i was told to try the pick up coil . and i bought a new one and still nothing .i checked all the wires all the grounds are still good and there is no loose wires anywhere . but when i turn the key to on it lets out 1 single spark as i turn the key . but when i turn it over theres nothing . and this problem is becoming very frustrating .. i just wanna ride my baby . pls help im completly out of idea's
Old 06-22-2007, 03:41 PM
DSNUT's Avatar
About the only thing left is the Rectifier located under the airbox. It is a little metal box with wires coming out of it. It has cooling fins on it. It kills voltage and if it no longer has continuity the bike won't have spark.
On most bikes the coil and plug wires would be suspect as well but the DS has two of each and the odds of both being bad at the same time are pretty remote........
I think you are to the point of replacing the rectifier as the next step.
Old 07-07-2007, 12:36 PM
Mitch101's Avatar
i finaly figured it out .it was the Tac that was causing me all the trouble . so i disconected it and it fired up right away . so thnx for the help guys . no needs to buy parts this time [img]i/expressions/face-icon-small-smile.gif[/img]
Old 07-07-2007, 02:41 PM
ERBEDS650's Avatar
<div class="FTQUOTE"><begin quote>Originally posted by: Mitch101
i finaly figured it out .it was the Tac that was causing me all the trouble . so i disconected it and it fired up right away . so thnx for the help guys . no needs to buy parts this time [img][/img]</end quote></div>
Did it some how ground out? 1st time ever of hearing this, most starting problems are from bad grounds.
Old 07-07-2007, 02:43 PM
Mitch101's Avatar
it must of been . were not exactly sure what was going wrong inside there . we came across the problem by chance . but chance or not shes running again
Old 04-18-2020, 04:11 PM
Jason Hackett's Avatar
i finaly figured it out .it was the Tac that was causing me all the trouble . so i disconected it and it fired up right away . so thnx for the help guys . no needs to buy parts this time </end quote></div>
where did you find the tac course I'm having the same problem?
Old 05-16-2021, 06:25 PM
Davidnshii Garcia's Avatar
Default what is the tac i have the same problem
i have the same problem what is the tac
Jmuddin284
06-28-2017 04:59 PM
coolguy420
07-10-2015 01:17 AM
DOC HOLIDAY
07-09-2015 01:09 PM
Mikea1978
07-04-2015 12:37 PM
Quick Reply: 2000 ds650 ignition problem still!!!!!
