04 eton viper90 won't start
Old 08-04-2007, 10:42 PM
TonkaDriver's Avatar
Default 04 eton viper90 won't start
Hi I have 04 viper 90 that cranks has spark but will not start. It does not even try to fire. Even with starting fluid I get nothing. I sprayed starting fluid before and after the carb. Have used a carb kit and replaced a all carb parts also. Any help and tips are greatly appreciated.[img]i/expressions/face-icon-small-confused.gif[/img]
Old 08-05-2007, 02:59 AM
Outlawlawndragster's Avatar
Try a new plug if you havent already. Also run a ground wire from the battery to the engine case. Have you done a compresion test if theres a hole in the piston it's not going to want to start. Also how does the spark look is it good and bright? One more thing remove the spark arrestor and try it. Good luck
Old 08-17-2007, 07:28 PM
harveje's Avatar
Switch out the CDI, I had some prob...about to check timing when I hooked a different CDI up and it fire on the second reveloution.......Darndist things.....make you cuss some times...
Old 08-17-2007, 11:01 PM
axle008's Avatar
I have a 110 and had the same problem , all I needed was a valve adjustment It had compresson but not enough to start
Old 08-18-2007, 07:19 PM
Trasher's Avatar
The 04 Viper 90 should be a 2 stroke engine so valves aren't a issue. My son has the same quad and it did the same thing one time. The oil injector system has been leaking and it leaked into the carb and engine also. I pulled the drain plug out from the bottom of the carb and let it drain out which was very oily. Then I turned the gas back on and let it run just for a bit. Put the plug back in and it fired up. Ran very smokey for a bit and tehn cleaned out and ran fine after that. I still had the issue of the oil injection system leaking which I will address later but it has bigger problems now. After a pretty good over the bars fall, the rear swing arm is bent with about a 5 degree twist in it. I am working on that now.
Let us know what you find out and good luck with it!
Old 08-18-2007, 07:21 PM
Trasher's Avatar
<div class="FTQUOTE"><begin quote>Originally posted by: TonkaDriver
Hi I have 04 viper 90 that cranks has spark but will not start. It does not even try to fire. Even with starting fluid I get nothing. I sprayed starting fluid before and after the carb. Have used a carb kit and replaced a all carb parts also. Any help and tips are greatly appreciated.[img][/img]</end quote></div>
I wouldn't use starting fluid in these little things, or just about anything else. You can use WD-40 to lit it off. I used to use that to fire off a build Jetski I had. Works great and won't do any damage.
jag6510
06-15-2015 05:59 PM
brinkkl2000
06-11-2015 12:46 PM
Fnqrider
05-31-2015 08:29 AM
1000gade
05-27-2015 12:37 PM
hot_shoe_cv
10-13-1999 02:16 PM
Quick Reply: 04 eton viper90 won't start
