Only remote start will start 110cc sunl
Old 10-03-2007, 09:00 PM
trentona1's Avatar
Default Only remote start will start 110cc sunl
Please help. I have a 110cc for my son that just died while he was ridding earlier today. When you push the start button on the switch nothing happens. But when you use the remote it starts right up and runs fine. Any suggestions on how to troubleshoot?
Old 11-07-2011, 12:12 PM
SteelersFan7's Avatar
Same thing with my nieces quad but she wanted the remote starter taken off so I did, now we can't get it started, no spark, no noises at all, cant jump it to start off the starter solenoid either. battery is fully charged and i have no idea what is wrong with hers
Old 12-07-2012, 09:21 PM
Steve Sindt's Avatar
Just unplug it when not using the atv, then plug it back in while using it. The (safety loop) goes into the remote box and then back out. It's like the kill switch on back has to complete or break the circuit to run. We have two and both kill the battery unless we unplug it. Also harbor freight sell float chargers for like 5.99 that can be mounted by the battery and then while not in use plugged in.
Old 12-20-2014, 07:39 PM
Kathy.ann.grant57@gmail.com's Avatar
[I bought a 3
5 3050 who wire harness came with everything But it has no remote I don't know what else plugs into it so no spark can I get some help
Old 12-20-2014, 07:49 PM
Default probelms/wire harness I bought.
Originally Posted by Kathy.ann.grant57@gmail.com
[I bought a 3
and the coil smokes when I try to start it
Old 12-20-2014, 07:58 PM
Default problem whit new wierharnas
I don't know what plugs into it help
Old 12-21-2014, 10:07 AM
Zrock's Avatar
one of your safety interrupts may have failed. Usually the brake handle is one and a tether on the back. Unplug one at a time and see if it starts. you may have to run a jumper wire across the plug. Some will work just by unplugging and some need a jumper wire.
Old 12-21-2014, 07:41 PM
Default problem with new wiring harnes
3.5 3050 who wiring harness I have all for unplugged in the back and there are two in the front unplug but i try starting it smoking out of the coil do you think the starter is shorting out the coil that's why there's no spark please. Help. Thanks
Old 12-21-2014, 07:51 PM
Default kathy.ann.grant57@gmail.c
I don't know what plugs into what
Old 12-21-2014, 08:02 PM
[QUOTE=Kathy.ann.grant57@gmail.com;3272093][I bought a 3
5 3050 who wire harness came with everything But it has no remote I don't know what else plugs into it so no spark can I get some help[/QUOTE. What else plugs into it
Quick Reply: Only remote start will start 110cc sunl
