DS50 loses speed to idle - help!!
Old 03-09-2010, 05:00 PM
1slow450's Avatar
Bringing this back from the dead
Im just wondering if you or anyone ever figured out what the problem was? I have a 90 doing the same thing.
Old 03-11-2010, 03:36 PM
schambo's Avatar
I would check the cables. I know, why? I have a 03 DS50 and it runs great. The only issue I have had is the left brake handle locking clip. You need to have this engaged to start it. Sometimes, it won't start or will stall when idling. If I fiddle around with the connection to the cable it will fire right up and ride fine. This doesn't happen frequently enough to be a problem but might be worth a look.
You have a lot of money into the quad now. Don't want to rub it in but I bought mine used 2 years ago for $750. It was barely ridden. Keep that in mind if it keeps acting up. Good Luck.
  #13
Old 03-12-2010, 10:46 PM
MRDS650's Avatar
Canadian and Proud of it !!!
Check the battery cables and the battery. The ignition on a DS won't advance with a poor battery or a crappy connection. Try charging the battery and then ride it - if it better it may be your battery. Even though the battery is new it could still be bad.
  #14
Old 03-13-2010, 07:18 AM
1slow450's Avatar
HMMM I was wondering about the battery because mine is dead. My daughter dosnet want me to buy a battery because she likes to kick start it.
  #15
Old 04-18-2011, 11:32 PM
Emsds50's Avatar
Default Can Am DS 50
Hi, I just recently bought my 06 DS 50. It appears we are having the exact same problem. Just wondering if you resolved your problem, if so what did you do? After several hours on the computer, my best guess is the auto choke has failed.
Thanks
Joe
  #16
Old 05-04-2011, 03:26 PM
chris26xxxl's Avatar
Default 2001 ds650
im having same problem as marti00 with my ds runs just like that battery acid dissapears i cant figure it out im thinking along thesse problems here key ignition coils cdi box regulator or stator but i dont want to replace with out knowing any help please
  #17
Old 05-04-2011, 05:03 PM
Emsds50's Avatar
I figured out that it was my auto choke flooding my ds. All I did to fix problem was unplug choke from carb...everything works great now.
  #18
Old 05-24-2011, 12:04 PM
jayjaysin's Avatar
I have an Eton 50 with the autochoke that does something similar when it's cold, and if I don't shut the fuel off when we shut it off it floods immediately. I was going to suggest the auto choke. I'll have to look at mine. I didn't realize you could just unplug it. Maybe that's what I need to do too.
  #19
Old 09-13-2021, 01:34 PM
Maverick762's Avatar
Default Bombardier 2 Stroke DS 50 Bogs Down
I know this is a very common problem with these machines. They have an electric auto choke on the carb. Simply unplug this. If you have trouble starting your machine in the future plug it back in to do so, then un plug it again. Took me some tinkering, but after scratching my head for a day or two I finally figured it out. Also just for any of you wanting to speed this thing up tremendously (from about 18 mph to 35+)you should buy the carb for the 2 stroke ds 90, the cdi box for the 2 stroke 90, and a 428-28 tooth rear sprocket (also be prepared to remove 3-4 links from your chain to install the sprocket). All of which will cost you a whopping 75 dollars on ebay. Your kid will be as stoked as if they got a new machine.
nowheeler
09-27-2016 12:18 PM
ZeroData
12-27-2013 12:19 AM
chuck1976
11-14-2008 07:55 PM
resqdoc
01-13-2008 09:39 PM
Quick Reply: DS50 loses speed to idle - help!!
