Exhaust pipe surface temperature
Old 02-02-2008, 04:17 PM
sheepdogMSP8117's Avatar
Default Exhaust pipe surface temperature
I just got a IR Pyrometer today, and checked the temps of my exhaust at a couple different locations.
Conditions:
Outside Air Temperature: 32* F
Engine temperature: Hot, just got done snowplowing and the radiator fan just got done cycling.
The general reading at the header pipe was 600*F.
The general reading at the header pipe heatshield was 350*F.
Its no wonder the plastic melts on these things!
I'm going to get the header pipe coated by Jet-Hot and then check the temps again. I'll post here with the results.
Old 02-02-2008, 04:20 PM
dwhst9's Avatar
Get the inside coated too.
Old 02-02-2008, 07:40 PM
Yep, the coating is inside and out, standard for header pipes.
Old 02-02-2008, 08:46 PM
stendori's Avatar
I'm watching you!
let me know how it works out sheep. i thought about doing that as well. pm me w/ cost and where you get it doen if you want. thanks
Old 02-03-2008, 04:00 PM
Stendori, I'll definitely let you know. In the mean time, I took these pics today.
Reading from left cylinder
Reading from cylinder head, left side
Reading from left header close to manifold
Reading from left header at second bend
Reading from heat shield
Reading from muffler
Reading from Benz Silencer
Reading from pipe just past the 2-into-1 joint
Old 02-04-2008, 07:54 AM
UTU's Avatar
UTU
UTU is offline
I had a 07 PoPo 800 done some bushoging and melted the seat,tabs on the front plastic and rear. traded off for a 08 and had the header jet-hot by jet hot cooled things down (:. happy camper
Old 02-04-2008, 09:05 AM
05twin700's Avatar
hey guys has polaris changed anything on the 08's to help out with this melting problem?
ive only got about 35-40 miles on mine but i have the 2yr extended warrenty.
Old 02-04-2008, 09:24 AM
stendori's Avatar
I'm watching you!
as far as i can tell from my 06' 800 to my 08' is that the heat sheild is bigger and the radaitor is bigger as it hold a little more antifreeze i think. no issues w/ melting on mine but only had 175 miles when i put it up. thanks sheep, ill be awaiting your results. thats some serious hot temps that your showing for sure.
Old 02-17-2008, 09:20 AM
patrolman800's Avatar
just found this out two weeks ago polaris has a service bulliton NOT A RECALL for 2005 2007 machines if your having hot exhuast problems or melting plastics dealers are to replace heat shields with better protective ones and they will reflash your computer on your machine to give it more fuel to cool down exhuast temp. this is the BIG problem they sent these machines out the door running so lean to meet emission regs that everybody is melting plastics off. I have had 2005 with two rear fenders replaced one side panel and no answer to why that machine ran so hot so dumped that got an 06 better but started to same problems just not as bad found out about this service bulliton and dealer put new heat shields on that really work and reflashed my computer and let me tell you a little more fuel gives you hole lot more pulling power. my exhuast temp before having this done running at an idle was 660 now its at 518,520 runing under load it would tach out my temp guage at 900 now it running at560 to 580 and it runs so much better that it not even funny it amazing. you guys with the o8 models already got these goodys. hope this helps some poeple out have seen alot of problems out there over the years now one of them is being fixed. also if your warrenty is up they will still fix they did for me
Old 02-17-2008, 12:32 PM
The last time I checked at my dealer about this, they didn't have a clue about reflashing. If you have access to this service bulletin, please get a copy of it so we can all see it. I'll even host it for you if need be. Short of that, I think a lot of us will be out of luck if we just walk into our dealers and say we read it somewhere. Without any actual proof, we won't be able to make any progress with them.
Quick Reply: Exhaust pipe surface temperature
