2008 Polaris 800 problem
Old 03-04-2008, 10:45 PM
UTU's Avatar
UTU
UTU is offline
Default 2008 Polaris 800 problem
My Polaris 800 has about 100 miles on it. When first started up in neutral want to stumble a lil bit. Let it warm up a minute no stumbling in neutral. After I let her warm up to operating temp and gas it from a dead stop want to spit back thru the intake a lil bit INTERMINTLY and not all the time. I can taks off slow till I get to around 2000-2500 and gas it no spitting what so ever. Took it too dealer and he replaced the plugs and adjusted the TPS. I am open for any and all suggestions on where to look now.????
Old 03-05-2008, 08:46 AM
stendori's Avatar
I'm watching you!
did it throw a code at you? is that why they adjusted the t-sensor on the intake? is this the bike w/ the key way in it adjusting the timing? just wondering if would all of sudden have anything to do w/ the computer timing being off? didnt get any water in the tank? howed the plugs look when they replaced them?
Old 03-05-2008, 10:11 AM
RolliePollieOllie's Avatar
My 08 800 behaved similarly and it was a loose negative cable at the battery. Make sure they are tight.
Old 03-05-2008, 12:43 PM
stendori's Avatar
I'm watching you!
that is a good point where these new bikes need a 12.8 volt charge all the time to run correctly.
Old 03-05-2008, 11:02 PM
UTU's Avatar
UTU
UTU is offline
No codes. Plugs were black that they replaced.Took timing key out back to stock b4 taking back to dealer.I drained the gas and replaced. This spitting is so intermint???? Checked the battery conection gonna check all the grounds and the positive on the solonoid etc. Im lost if I can not figure out I guess its back to the dealer again????
<div class="FTQUOTE"><begin quote>Originally posted by: stendori
did it throw a code at you? is that why they adjusted the t-sensor on the intake? is this the bike w/ the key way in it adjusting the timing? just wondering if would all of sudden have anything to do w/ the computer timing being off? didnt get any water in the tank? howed the plugs look when they replaced them?</end quote></div>
Old 03-06-2008, 07:48 AM
stendori's Avatar
I'm watching you!
do you think the the t-bap sensor has got moved and check the connections real good. i was reading the manual about the efi and it says about 80% of problems are due to bad connections on any of the componets. worth a look.
Old 03-06-2008, 07:53 AM
UTU's Avatar
UTU
UTU is offline
t-bap sensor? TPS throttle position sensor?
do you think the the <u>t-bap sensor</u> has got moved and check the connections real good. i was reading the manual about the efi and it says about 80% of problems are due to bad connections on any of the componets. worth a look.</end quote></div>
Old 03-06-2008, 12:28 PM
stendori's Avatar
I'm watching you!
no not the tps, thje sensor that sits on top of the intake behind the airbox toward the engine.
Mkp
03-28-2020 03:50 AM
Mphillips
07-29-2015 08:53 PM
TJM
06-11-2015 01:28 PM
RedRancher
06-04-2015 12:29 PM
Schneider
06-04-2015 11:37 AM
Quick Reply: 2008 Polaris 800 problem
