2001 Bayou 220 - starter motor
Old 03-10-2008, 01:44 PM
meatdogspot's Avatar
Default 2001 Bayou 220 - starter motor
I am attempting to replace the starter motor and have followed the instructions stated in the service manual but am unable to pull it off the bike. Any ideas or tricks for removal?
Old 03-11-2008, 10:05 PM
chasenfish16's Avatar
I just did some work on one, what are you having a problem with?
Old 03-16-2008, 11:26 PM
I followed, to the letter, the service manual on how to remove everything to get to the starter motor and everthing came off like clock work until it was time to pull the starter motor. I was unable to extract it from the bike. Based on the service manual and from what I could see, there is only one bolt that holds the starter motor to the bike. I hit it with a mallet a few times but it didn't budge. Any ideas?
Old 03-16-2008, 11:58 PM
There are two bolts that hold the starter in place, they are both on the back side.
Old 03-17-2008, 08:30 PM
Once the bolts are out, should it slide out easily or is there a trick?
Old 03-17-2008, 08:43 PM
Mine was a little hard to get out, carefully pry between where the starter goes into the engine. There is an o-ring in there that holds it in snug.
Old 03-17-2008, 09:23 PM
i'll give it a shot
ghost civic
01-15-2020 07:43 AM
Sjrpp
06-02-2019 07:25 AM
JoAnnS
07-23-2015 02:18 PM
rcappie4
07-18-2015 07:51 AM
ghost civic
07-15-2015 10:48 PM
Quick Reply: 2001 Bayou 220 - starter motor
