2007 420 rancher winch
I purchased a Gorrila w/ the syn rope, 2500bl. for my 420 and have been totally satisfied. Everyone says they are a spiten' image of the warn winch. A little tricky to get mounted. You have to remove the plastic cover over the push bar and take the push bar loose to get it in place, No big deal.
I have a 1500 Warn on mine and was told by Honda that that is all they recommend for the Rancher due to people stretching out frames by chaining the bike to a tree or something. Also, on account of the smaller space behind the bumper, they had to crack the winch open and spin it 90 degrees so the release lever is almost up on top of it.
Is the winch from MotoAlliance? I got mine form them via their website.
Gorrilla = Garbage
Warn = a good time while riding
I have been through 3 gorrilla winches. This first 2500 would not lock up right out of the box, they sent a new drive shaft and gear. Stated they knew there was a manufactuer defect. Repaired it, lasted for only 1 ride, sent it back got a new one. It locked up also. The repaired one was shipped back to me and I gave it to a friend to put on his 420 AFTER his 2000 gorrilla failed. The repaired one failed shortly on his bike.
I bought a RT25 and so did my friend, wish we had done it the first time. The only good thing from Gorrilla is the winch plate.
Spend the money and save the headache!!!!!!!!
Warn fits nice and tight in the bike. You will need to trim the front pushbar plastic to make the fairlead roller bracket and the ends of the winch fit.
