vin number
Old 04-06-2008, 10:01 PM
oldpiston's Avatar
Default vin number
Alright I'll admit it, I have no idea what I am doing. I have two broken down Kawasaki Bayou 220's and want to make one. Where can I find the vin number and a cheep repair mainual? Thanks guys
Old 04-08-2008, 07:38 AM
JustRandy's Avatar
Default vin number
VIN number should be on the frame somewhere. Towards the front and on the left would be my guess. Get a wet rag and start wiping mud away from the frame tubes till you find it.
A manual can be had from rockymountainatv, bikebandit, ebay, or any place like that online for around $30 or so. Amazon sell lots of used books, maybe they have one for $1 or something.
Old 04-08-2008, 06:51 PM
oldpiston's Avatar
Default vin number
Thanks for the info. Considering that I am totally in the dark ---- I will be back. Keep an eye out for <span class="FTHighlightFont">oldpiston</span ft>
Old 04-08-2008, 07:50 PM
JustRandy's Avatar
Default vin number
k
Old 04-08-2008, 11:51 PM
alisonsandmindysdad's Avatar
Default vin number
The VIN is on the left side of the main frame tube, behind the left front tire/wheel. Don't waste your money on an "off" brand manual...go on ebay and find a used genuine Kawasaki KLF220 Bayou service manual. Most parts on the Bayou 220/250 will interchange from 1988 to present. There were some changes in the electrical parts (key switch, harness, etc.) and in the front bumper/front rack. The 250 has a 1.00 mm larger bore/piston, but other than that they're basically identical. Tons of used Bayou parts on ebay.
I rebuilt a Bayou 220 for one of my sons. I learned a few tricks along the way. There are a few pics in my profile. Good luck with your project!
Old 04-09-2008, 12:11 AM
JustRandy's Avatar
Default vin number
That rang a bell.... Someone posted on here a while back about trying to rig an older CDI on a newer bayou (or vice verse, can't remember). It won't work because they changed the number of wires coming out of the alternator and/or cdi. My Clymer manual has 5 wire diagrams for the bayou.... 88-90, 91-95, 96-99, 00-02, and 03. Actually, I'm kinda impressed with this particular clymer manual. It even has a procedure for testing the cdi. You don't find that very often in atv's. However, in general, clymer usually does leave some things to be desired.
Old 04-09-2008, 05:36 AM
Default vin number
When you start looking to interchange different parts, if you have any questions as to interchangability, go to www.buykawasaki.com, then click on "owner info" and then "parts diagrams". It will help you a bunch with exploded pics, part numbers, etc. You can also enter your VINs there to see what year B220s you have.
Old 06-02-2018, 12:10 PM
Happychap92's Avatar
Default Vin number
Hi just wondering if anyone could help me out with how many digits are in the vin number on a Kawasaki klf220 guessing it should have 17 but can only find 15 on mine any help would be appriseated
ReconBayou
10-16-2019 02:24 AM
Johnny Mac
08-15-2019 03:13 PM
cswiger
Polaris Side by Sides
12
10-05-2015 03:34 PM
Quick Reply: vin number
