2006 Rancher AT esp shift code
Old 05-09-2008, 11:35 AM
fishands's Avatar
Default 2006 Rancher AT esp shift code
Hi folks,
I have a 2006 rancher at 400. Had an esp code blinking 6 times I reset the position angle sensor and cleaned and greased all the conectors. Now I have a error code blink 12 now. Any comments would be great.
Thanks,
Fishands
Old 05-09-2008, 05:50 PM
cody_lyons78's Avatar
0 blinks: No problem
1 blink: ECU
2 blinks: ES Shift up / down shift system or shift release / related wire harness or ECU
3 blinks: Angle sensor
4 blinks: Gear position switch system
5 blinks: ECU motor driver
6 blinks: ECU fail-safe relay circuit
7 blinks: ECU Voltage convert circuit
8 blinks: Angle Sensor control motor
9 blinks: Angle Sensor short or related wire
10 blinks: Ignition pulse generator
11 blinks: Speed sensor
12 blinks: Gear position switch
its probably your gear switch but i posted the rest of the codes in case you have any more problems. i think all these problems people have with ES should tell honda something
Old 05-09-2008, 08:23 PM
HondaMechanic's Avatar
The TRX400FG/FA Hondamatic codes are ...
This is the tests for code #12 ...
Old 02-13-2022, 02:37 PM
Pue707's Avatar
Default Rancher wont start
I have a 2006 Honda Rancher 350ES 4x4.....the shifter position shows --- but the green neutral light is on. The darn thing turns over but wont start...CDI just changed.....no spark at the spark plug
Old 02-14-2022, 03:09 AM
The 350ES has a totally different engine and gearbox to the 400AT. Try changing into 1st with the manual gearchange lever, then change back down into neutral. The --- mean it is in between gears, unless they are flashing Morse, in which case they are telling you which fault is on, not sure if the above fault code list is for the ES or the AT, the person who posted it seems unclear.
Pue707 (02-14-2022)
Old 02-14-2022, 09:57 AM
Pue707's Avatar
Thanks for the feedback….I did try to manually shift it as well as tried to rock it back and forth but no luck…I order a reveres sensor and have been plugging and unplugging wires in hopes to find something….was working fine and then blaaa
Old 02-15-2022, 03:20 AM
If it won't shift with the emergency lever, remove the shift motor, if it still won't shift manually, you have a mechanical problem with the linkage inside the clutch cover. Usually it is the lever which engages the pawl that turns the star wheel, or the pawl, broken or cracked, or the star wheel come loose on the end of the shift drum. However on 350s only, I have known the rod which holds the shift forks to break through the crankcase into the clutch housing.
Red2000z28
12-14-2010 09:18 AM
Bigdrap660
01-12-2009 10:38 AM
forgepro
12-28-2008 10:29 PM
4staroffroad
05-06-2008 07:14 AM
lucleb
01-08-2008 02:30 PM
Quick Reply: 2006 Rancher AT esp shift code
