Rubicon stuck in gear
Old 06-03-2008, 09:43 AM
bullfrog7286's Avatar
Default Rubicon stuck in gear
Hey everyone, i am new to here and i wanted to see if yall could help me. i have a 2004 rubicon. I sunk it in some deep water. When i got it running it was stuck in 3rd or 4th gear and reverse has like a governer on it. Now its stuck in 1st. It Does go for high to low. The screen is flashing the d1 d2 d3 signs. I have disconnected the battery and the computer.That didnt help anything still doing the same thing. Anbody have an idea of what might be going on?
Old 06-03-2008, 12:30 PM
HondaMechanic's Avatar
You have to count the number of flashes ..
Old 06-03-2008, 12:41 PM
it never stops it just keeps flashing
Old 06-03-2008, 05:19 PM
Old 06-03-2008, 10:12 PM
ok see if this sounds right i had eleven blinks. Does that sound right?
Old 06-04-2008, 02:44 PM
ok i take that back the first series of blinks is 5 then it goes to 10 blinks
Old 06-05-2008, 05:05 PM
wow thanks for the help guys..............
Old 06-05-2008, 05:35 PM
fourwheeldrive's Avatar
Full Time DAD!
Well, according to the blinks you indicate, it is giving a current code and an earlier code. Current code is 5 and earlier code is 10. I believe 5 is the Angle sensor system and 10 is the code for Fail-safe relay circuit malfunction. Don't hold me to that. Hondamechanic would have much more knowledge on this than I.
From reading your original post again, I'd say to check the elec. connectors and make sure they are all dry. If these connections get water in them, it can cause this kind of problem.
Old 06-06-2008, 07:45 AM
well its been like 3 weeks since it was sunk. do i still need to pull all them out and dry them?
Polaris5
08-29-2015 09:11 PM
heath legg
07-24-2015 01:01 PM
micheleLeigh
Technical and How-To Articles
07-19-2015 07:32 AM
ghost civic
07-15-2015 10:48 PM
sara durrant
07-06-2015 05:32 PM
Quick Reply: Rubicon stuck in gear
