2003 Honda Rancher ES shifting Problems
Old 06-11-2008, 06:25 PM
MustangMatt96GT's Avatar
Default 2003 Honda Rancher ES shifting Problems
This is my first post. I tried searching around a bit, but couldn't find an answer. I am mechanically inclined and have no problems doing work my self.
Question is:
The 2003 Honda Rancher 350 ES 4x4 had problems shifting into reverse last year after the engine was warmed up. It occasionally would work, but most the time it wouldn't. So fast forward to this year. The first ride, the ATV did alright. But now after it got parked, it now will no longer shift into or out of any gear with the buttons. I have to use the manual shifter.
What might cause this? I am looking to get the parts to fix it and take them up to the cabin next week and fix it. Is it possible the ECU is fried?
Thanks for any help. Also ask any questions, and I will answer them the best I can.
Matt
Old 06-11-2008, 08:06 PM
HondaMechanic's Avatar
First make sure the battery is in good condition , the 2003 TRX350FE should flash a trouble code ..?.. Is your gear position indicator not flashing a code..?..
Old 06-11-2008, 08:11 PM
No its not flashing anything as far as I know. Dad is just relaying the message to me right now. I have not tried or been close to the machine since around christmas. But the battery prolly could use a charge from sitting, but it was good when we got it.
Old 06-11-2008, 10:00 PM
Turns out that he was out riding when it happened. He went 1st to 2nd no problems. 3rd and forth no problems. Then he tried shiftiing down from 3rd to 2nd, and it wouldnt shift and the place in the dash just gave dotted lines. Would that indicate just a bad battery?
Old 06-12-2008, 07:59 PM
I guess im just going to buy a new battery and see how it does. Should work out... Where would i be able to get one? The dealer ship? Anyother place?
Old 07-20-2008, 01:36 AM
larrob44's Avatar
[img]i/expressions/face-icon-small-disgusted.gif[/img]
I have had two, now the third shift motor assembly. The problem is worse when the engine is hot sometimes but you never know when it will occur. Sometimes it works on rare occasions, sometimes no problem, most of the time it's "get out the wrench and drive in one gear. Two trips to the dealer with no better results. I have heard from others that have the same issue.
Mine has been used very little; actually because of the shifter I never know when it will work, it's just not reliable.
I am adding a stick shifter and forget about the piece of junk electric.
I would sell it but do not want to stick someone with the aggrevation.
Artic Cat is a much better machine, Yamaha second, Suzuki third, Kawasaki fourth; the Honda Rancher is dead last. I'll buy a no name before Honda.
Old 07-20-2008, 07:55 AM
MustangMatt96GT if your gear position indicator isn't flashing a trouble code then your bike is a 2000-02 model and you have to follow the troubleshooting flowchart for the ESP .. And if it is an 03 and your indicator isnt flashing then your dealer should have contacted Honda ..
Old 07-20-2008, 02:28 PM
Well i replaced the battery, and guess what...
Its been working for a while now. Thanks though.
neilbedwell
11-10-2018 11:02 AM
Jake55
06-29-2015 06:43 AM
ROWALKER
06-15-2015 05:38 PM
Dpearson03
Utility ATVs
05-29-2015 04:51 AM
aby11
05-07-2000 07:58 PM
Quick Reply: 2003 Honda Rancher ES shifting Problems
