1993 Honda Fourtrax Starter Problem
Old 06-14-2008, 04:30 PM
Pkeeper52's Avatar
Default 1993 Honda Fourtrax Starter Problem
I have been having trouble with my fourtrax 300 starting. I can start it manually with the Kick starter with no problems. I checked out the fuses and all good, I replaced the starter because that was what I thought problem was but it had no effect on the starting problem. When I push the starter button, it "Clicks", but the starter does not turn over. The "Relay" is the item that has an audible "Click" when the starter button is pushed. Any help would be appreciated. I do not want to take it to the shop unless that is the last resort. PLEASE ADVISE.
Thanks much, Pkeeper52
Old 06-14-2008, 06:47 PM
HondaMechanic's Avatar
Have you checked the battery & ground connections and tested the solenoid ..?
Old 06-14-2008, 07:32 PM
brad0213's Avatar
yea u have a point the battery could just be dead or the power is not getting their
Old 06-15-2008, 11:54 PM
Pkeeper52's Avatar
Honda Mechanic, Thanks for the prompt reply. After we installed the starter I tried one more time to start it using the "Start" capability of my battery charger (I had already charged the battery for 14 hours or so and was sure it was up to snuff), well you are exactly right...it started just fine. It was a combination of battery and starter together and somehow the "start" power of the charger kicked the battery into high gear and started it. We have been using it for two days now and it starts fine each time. Thanks for your input and support.
Pkeeper
'86 TRX125
06-06-2015 07:43 PM
volsgo30
06-04-2015 06:07 PM
PuhiStrain
09-09-2000 01:36 PM
blazer316
09-08-2000 10:53 AM
lovinhonda
01-25-2000 09:17 PM
Quick Reply: 1993 Honda Fourtrax Starter Problem
