04 rancher 350 won't shift into reverse....
Old 08-07-2008, 08:12 PM
hanginout's Avatar
Default 04 rancher 350 won't shift into reverse....
I've got issues with my rancher not shifting into reverse. First, it has a brand new battery....Shifts fine up and down but absolutely will not go into reverse. Also blows a fuse when front brake is applied... Does anyone out there have any ideas???? I'm not really close to a honda dealer so I hope to avoid a trip...
Tanks in advance!!!
Old 08-07-2008, 10:34 PM
jyorkie94's Avatar
That happened to my friend. After awhile of no reverse he decided to go tapping around on the 4 wheeler with a hammer and it fixed it so i am not sure what the problem is. Haha i probably wouldn't recommend doing that. O but he didn't have the front brake problem.
Old 08-07-2008, 11:31 PM
ride_2die1's Avatar
my honda rancher 350 didnt reverse either....if u tap the back brack cables which are on one of the rear wheels with a hammer it might work thats what work s for me at least
Old 08-08-2008, 06:55 AM
HondaMechanic's Avatar
First adjust the reverse lock cable..
If the bike is an ESP model (electric shift) check the reverse switch on the lower rear of the engine to make sure it is pluged in ..
Old 08-08-2008, 06:57 PM
wowkoolaid's Avatar
hey hondamechanic would it hurt anything to run with the reverse lockout lever engaged all the time to eliminate the reverse button on the rancher
Old 08-08-2008, 08:22 PM
Not as long as your VERY careful when down shifting .. I have mine tripped during the winter when I use the plow a lot but you have to be careful ...
Old 08-10-2008, 12:31 AM
hanginout's Avatar
Thanks to all who responded... The cable was unplug and shorting out on the motor. Plugged it back in and everything works great....
Old 08-10-2008, 01:37 PM
Gimpster's Avatar
<div class="FTQUOTE"><begin quote>Originally posted by: HondaMechanic
Not as long as your VERY careful when down shifting .. I have mine tripped during the winter when I use the plow a lot but you have to be careful ...</end quote></div>
I run mine tripped al the time also. I can relate a few war stories about hitting reverse while downshifting. Not fun
----- Gimpster -----
Old 10-03-2008, 01:30 AM
Liam1234's Avatar
Hi Guys,
Need your help. Last ride I ended up scraping a tree and the reverse cable at the handlebar came loose and I need to replace the cable.
The cable did not show up in time to my house and I have a rather long ride planned fo rthis coming Saturday.
I want to run my bike in the tripped mode until my calb ecomes in.
How do you actually trip it? I wen tunder my bike and found the reverse lock out cable and lever and was able to move the lever with a screwdriver but it springs back.
How do you trip it so it stays tripped?
THANKS
Old 10-22-2008, 10:24 PM
tripp0113's Avatar
I would like to thank all of you who take the time to read our problems and answer the questions you know. I have never posted to the site nor visited it until today. I have a 2001 Rancher that suddenly would not shift into reverse. I read many, many posts and happened upon this which was perfect. The pictures helped greatly. Once I knew where to look, it was easy to see that the reverse switch on the engine was unplugged. I plugged it in and everything works perfect again.
Thanks again
Tripp
Quick Reply: 04 rancher 350 won't shift into reverse....
