ATC 185 Recoil Starter and Decompression Cable
Old 09-07-2008, 10:33 PM
dgilfillen's Avatar
Default ATC 185 Recoil Starter and Decompression Cable
Hello,
I am trying to reassemble the recoil starter on my ATC 185S (1983).
The rope broke, but I fixed that. Now, I am trying to reassemble the decompression release cable and spring in the recoil.
I know there are parts diagrams out there, but none show the assembled parts very well.
I am pretty mechanically inclined, I just need a little help "talking" me through it.
All the parts are there - nothing is missing.
Thanks!
dgilfillen
Old 09-09-2008, 09:19 PM
dgilfillen's Avatar
Fixed! I found some images online that showed how the spring went back together, and I got it all put back together! The trike is now MUCH easier to pull!
dgilfillen
Old 01-05-2009, 10:45 AM
popsfarm's Avatar
Hello: I have the exact machine and problem, would you please let me know where I may downlocd the information which solved your same problem. Thanks, Jerry
Old 01-05-2009, 11:19 AM
dgilfillen's Avatar
Man... I cannot remember for the life of me where I found it, but I did a google search.
I will look through my stuff and try to get you the images.
If you need, we can probably discuss this over the phone. PM me.
I fixed mine and it ended up being really easy!
Daniel
Old 01-05-2009, 12:32 PM
dgilfillen's Avatar
I found it!
The link is here:
http://www.3wheeler.org/vb/showthread.php?t=29209
You will have to login to see the images.
Good luck!
dgilfillen
Old 01-05-2009, 12:45 PM
dgilfillen's Avatar
popsfarm,
Please also note the the Honda service manual explains how to do this. It is in steps 17-27 of the scanned document in the link I listed above (same page with image #198 in the upper left corner).
If you combine the words from the service manual and the pictures from the above link that the gentlemen took of him actually doing the installation, you should get it.
Good luck!
dgilfillen
Old 01-05-2009, 06:59 PM
popsfarm's Avatar
Daniel: For some reason I cannot log in to receive your message, please contact me thru email at cgschulin@gmail.com. Thanks, Jerry
Old 05-02-2009, 01:59 PM
hi i was wondering were you found those images could you send them to me i have the same problem with the decommpression cables thanks
akguy31
08-31-2019 04:34 AM
Coondoog
Technical and How-To Articles
09-09-2015 01:51 PM
craacker
09-09-2015 04:32 AM
Pahuntman
09-05-2015 11:07 AM
mrmickman123
08-30-2015 10:37 PM
Quick Reply: ATC 185 Recoil Starter and Decompression Cable
