1987 Suzuki lt250 Hard start
Old 09-11-2008, 06:34 PM
lt250 4x4's Avatar
Default 1987 Suzuki lt250 Hard start
I have a 1987 Suzuki lt250 4wd. I have fully rebuilt this engine.. great compression but I havent done anything to the carb yet.. The starter is locked up so I have to pull start it.. Takes about 20 times to get it started with the pull starter and sometimes requires a cap full of gasl put into the carb. Once the ATV starts it runs great and starts on one pull start everytime until the following day.
Any suggestions on how to fix this or where to start with.. I dont want to burn up a new starter cranking it too much.
Thanks
Chris
Old 09-12-2008, 11:13 AM
LT80's Avatar
LT80 Expert
You didn't clean the carb?
Maybe the timing is off a notch?
Old 09-12-2008, 08:35 PM
lt250 4x4's Avatar
NO I havent cleaned the carb out yet.. planning on doing that this weekend..
TIming is dead on.. I was kind of **** about that ... Once I start it for the day it runs all day long fine and restarts with one pull.. When it sits overnight it is hard to start. I am also going to check the valve adjustment as well.. The preious owner didnt take good care of the ATV so I am working on that little by little.
Old 09-12-2008, 09:56 PM
TLC's Avatar
TLC
TLC is offline
Clean carb Easy How To Instruction
Make sure the choke enrichment plungers are not stuck in the carb, if it is not coming up, no additional fuel is delivered when you "choke" the engine.
If pilot jet will not come out just use the wire and spay without removing the jet,better than mangling the jet's slot at least.
Old 09-24-2008, 12:14 PM
Onesmokinduramax04's Avatar
<div class="FTQUOTE"><begin quote>Originally posted by: lt250 4x4
Thanks
Chris</end quote></div>
Hey did you ever get your quad to start easyer?
Im having a hard time starting mine as well not sure if its in the carb or timing... Mines a 89. I just got it and rode it the other day and had a hard time staring it even when it was warm.... any in would be great.
Old 09-24-2008, 11:15 PM
lt250 4x4's Avatar
Yeah i got mine up and going great..
I adjusted the valves, new spark plug and cleaned the carb out..
Does it drive fine ? My intake valve was a little tight and exhaust vale was loose.
MOst likely I would clean out the carb first and a new plug .. I didn't even need to replace any gasket on mine and no leak after it was back on.
Old 09-24-2008, 11:25 PM
It drives fine I was pulling a small trailer it ran best in 4 low... Not sure why... How hard was it to clean the carb? Me and carbs dont get along lol.. do you know what the specs are for the valves? I did put a new spark plug in it didnt seem to help...
Thanks for geting back to me
mark
Old 09-24-2008, 11:30 PM
lt250 4x4's Avatar
I just sold my this week to get my son another one.. let me go check with feeler guage i used real quick its still out
Old 09-24-2008, 11:37 PM
lt250 4x4's Avatar
just checked.. they actually have different ranges for the intake and exhaust valves.. they verlap though. SO I used the one in between that coul dbe for both. It worked perfectly. .005" / .127 mm was on the feeler guage I used.
AS for the carb.. I just took it apart slowly one screw at time.. soaking the jets in a little carb clean.. Just set everything in order as you take it out.. I blew some of the air passages out with a little bit of low air pressure to make sure no dirt was inside. The mixture screw I set somewhere's around 1 3/4 to 2 turns out. The idle I adjusted accordingly to get a smotth idle. ON the left handle bar there is a lever for the choke at starting ..its helps if you pull that down.. took me some time to figure that out as well.
I can try to answer anything else just let me know.
Old 09-24-2008, 11:41 PM
That was fast man! thanks alot.. I cant get to talking it apart in till some time next week... If i get in a hard spot ill try to send you a pm... Thanks again man
Quick Reply: 1987 Suzuki lt250 Hard start
