Moto 4 Oil and Capacities
Old 11-18-2008, 10:26 AM
1badtacoma's Avatar
Default Moto 4 Oil and Capacities
I have a Moto 4 200cc Yamaha. Can anyone tell me what Type of oil I need and how much? Also what brand filter should I get?
Thanks,
Old 11-18-2008, 01:25 PM
tripleR's Avatar
I did not know they made a 200 Moto 4. I have a 225 Moto 4 and according to the manual it takes 2.2 quarts of either 10-30 or 10-40 depending on the temperature. I have used Penzoil in mine since I got it. On mine, again according to the manual, you do not change the filter, you simply remove it, clean and reinstall.
Old 11-18-2008, 01:34 PM
1badtacoma's Avatar
Yes it is indeed a 200. So you dont change your oil filter? or did you think I ment air filter?
Old 11-18-2008, 01:47 PM
tripleR's Avatar
I'll be darned, never saw a 200, I thought the YFM225 was the smallest made. No, I meant the oil filter. According to the manual, you remove it, clean it and reinstall. On mine, it is not a "cartridge" type, but is rather inside the engine case. To be honest, I do not do much in the way of maintenance on mine. I just changed oil in it for the first time in three years, don't fool with the air filter much either. Of course I don't ride it much anymore, but can't stand to get rid of it. I have been using a Rhino, 700 Polaris and now 700 Grizzly 700 EPS and only using mine as a spare. I got it in 1989 and have never had it in the shop, but of course when I used it regularly I did maintain it well; very reliable little machine.
Old 11-20-2008, 12:55 AM
1badtacoma's Avatar
I figured out the exact model its a yfm200dx moto 4 shaft reverse. the DX was made in 87,88 and 89. but the 87 was an dxt and the 88 was an dxu and the 89 was dxw. I wonder what the differenses were. anyone know where I can get a repair manual from?
Old 01-03-2009, 06:39 PM
dealer374's Avatar
I have a Moto-4 which I was told was and 86 it 223 on the cyclinder head so I'm assunming its a YFM225 is that true. If so i cant find a place that matches that model number with that year what is my model number? YFM.........????
Old 01-03-2009, 06:50 PM
tripleR's Avatar
Yes, it is a YFM225 and should look just like this one or in blue.
http://www.youtube.com/watch?v=aNIH61KILds
Old 01-03-2009, 08:27 PM
TLC's Avatar
TLC
TLC is offline
I thought they all had the 229cc motor, some where called 200 others where called 225 my 88 was called a 250 but it had the 229cc motor as well.
Old 01-03-2009, 08:46 PM
tripleR's Avatar
There is a difference in the two motors. I guess if yours is an 88, that is when the designation changed as my brother has a Yamaha Timberwolf 250 with the 229 cc engine while my 87 Moto 4 YFM225 has the 223 cc engine. I don't know what difference there is in the engines or transmissions other than his does not have the dual-range transmission like mine and is a mono-shock I believe; don't remember the year model, but it was somewhere in the 90's.
Old 01-03-2009, 08:54 PM
TLC's Avatar
TLC
TLC is offline
Mine had the low range also ,very handy some times even on a 2wd.
Quick Reply: Moto 4 Oil and Capacities
