Outlander 4x4 not working
Old 01-19-2009, 10:23 AM
hworcester's Avatar
Default Outlander 4x4 not working
Looking for insight on Outlander's 4 wheel drive not coming on. I have an 03 Outty 400 with about 1500 miles. Tried to pull the kids on sleds other day and found out my 4x4 was not kicking on, no 4x4 light, no sound when the 4x4 switch is flipped. All 4 fuses look good. No idea where to start my trouble-shooting.
Has anyone experienced this problem?
Old 01-19-2009, 12:43 PM
BBR650's Avatar
Is always changing bikes.
plug could be dirty from the switch to the harness???? switch could be bad??
Old 01-19-2009, 12:47 PM
Steveo10's Avatar
is there a fuse box at the rear?
or
take the switch apart and clean it
Old 01-19-2009, 02:35 PM
hworcester's Avatar
Only fuses indentified in Owners manual are 4 of them in front of the radiator in the front storage area. All four were in good shape. I also saw a Utube video showing how to troubleshoot and waterproof the 4x4 switch. I plan to try that next.
Old 01-20-2009, 01:16 PM
Steveo10's Avatar
ya i figured since it was a 03 that there wouldnt be any fuses in the rear.... the connections probably just have to be cleaned in the switch
Old 01-20-2009, 02:14 PM
hworcester's Avatar
The 4x4 switch looks fine. I took it apart and no evidence of water or corrosion.
Next I wil check the wiring and make sure there is no corrosion/broken wires, and verify that I am getting power to the actuator.
I hope it is not the acutator, looks pretty pricey.
Old 01-28-2009, 07:42 AM
1988TRX250R's Avatar
<div class="FTQUOTE"><begin quote>Originally posted by: hworcester
I hope it is not the acutator, looks pretty pricey.</end quote></div>
Not to mention a pain to replace. I have replaced a few actuators on the Outlander 400's. You have to remove the front shaft, and then remove the housing the actuator attaches to. There is a piece inside that usually breaks, it is shaped like a fork that slides a shaft back and forth to engage the front wheels.
hugemoth
07-20-2020 03:28 AM
timster911
07-13-2015 01:57 PM
RedRancher
07-10-2015 06:36 PM
J-Mack
Polaris Side by Sides
07-04-2015 04:19 PM
bikedad3
07-02-2015 02:15 AM
Quick Reply: Outlander 4x4 not working
