raptor 660
Old 01-30-2009, 09:00 PM
raptor25's Avatar
Default raptor 660
would it be worth it for me to get a k&n air filter, dynojet jet kit, dynatech cdi box,and a yoshimura exhaust. I really want to get these upgrades, but i want to make sure that it will increase performance and throttle response
anyone help!
Old 01-31-2009, 03:20 AM
bigned1904's Avatar
Default raptor 660
i would highly recomend getting a ct exhaust rather than a yoshi. not sure on cdi boxs but i think ive herd they r a rip
Old 02-01-2009, 02:49 PM
raptor25's Avatar
Default raptor 660
thanks..about how much would it be for a decent ct full exhaust?
Old 02-03-2009, 05:56 PM
SCHOLLE's Avatar
Hasn't given up on the 660 just yet...
Default raptor 660
Skip the CDI its useless you plan on MAJOR mods. Barkers dual exhaust make the most power on the Raptor period. The singles I like Sparks. The CT is ok but not as nice looking of a pipe. Power Pro builds CT, Graydon just to name a couple.
The Yoshi full systems make very good power if you dont plan on any more work.
There is a HUGE difference in a good clamp on filter ( no lid ) or eliminate it all together, proper tuning ( ie jet kit ) and a full exhaust.
I like the dynojet stage 2 kits for stockish bikes with those mods.
Old 02-13-2009, 12:57 PM
raptor25's Avatar
Default raptor 660
i am looking to spend around 800 in mods for my 05 raptor 660.......i am very confused.....what should i get?
Old 03-02-2009, 01:43 PM
Flybynight's Avatar
Default raptor 660
I would go with Scholle on the duals. I recently had my 2001 Raptor 660R rebuilt and I added the Barkers dual exhaust. I have yet to see it because I have to go pick it up this weekend, but they came highly recommended. Try to get away from the stock air filter and airbox. These machines are nearly choked to death when they are stock. You will notice a huge gain by allowing them to Breathe. I know you only want to spend $800, but I set myself a limit of $1,000 for mods two weeks ago, and I have surpassed that by far. Of course, willingly. If you are talking about wanting to do engine mods, I found a shop that rebuilt my Raptor with the 686 Big Bore Kit. they also added a High Performance stage 1 head kit, as well as a Raptor High Performance stage 1 top end kit. These mods on top of the exhaust cost me roughly $2,200 but my bike is the way I want it now.
Old 03-29-2009, 03:56 PM
boudro13's Avatar
Default raptor 660
any exhaust u put on ur raptor will give it more power but i would recommend at least a full exhaust. Yamaha has the most restricted exhaust on the market. when u do the exhaust you will have to rejet so u will require the jet kit.
as for the air filter i'd look for the set up so that ur air filter is clamped in your air box instead of the stock setup. cause otherwise u have to butcher ur lid and if u mess with water to muck i'd forget about the k&n and run a 2 stage foam.
the cdi box, just forget about it, it's a waste of money in my opinion. all it does is allow the motor to pull even more rpm's and it can b rough on engine that is internally stock
Old 04-14-2009, 01:28 AM
tfunk22008's Avatar
I wouldn't get the rev box because the raptor is not meant to be high end like the 450s they are better a gear higher and pull through the gears because of the torque id just get a full exhaust which will be 500-600 and depending on the air filter i would definetly go with the clamp on mod and that will be under a hundred
Old 04-20-2009, 02:38 PM
"beast"lakota-300's Avatar
i wouldnt go with the dual in less you plan on some internal mods. happy trails.
bmxatv10
10-14-2022 06:23 PM
black_thunder
09-22-2015 07:59 PM
Alex Rodak
09-13-2015 12:30 AM
Alex Rodak
09-12-2015 09:39 AM
Alex Rodak
09-11-2015 11:42 PM
Quick Reply: raptor 660
