450r starting problems??????
Old 03-01-2009, 01:26 PM
450rbaby's Avatar
Default 450r starting problems??????
hi i have an all stock trx450 and it is super hard to start its almost brand new only and 07 i changed my spark plug and it still has to crank over alot and i have to play with the throttle and choke to get it started i would like to figure out how to fix due to i race and can't have a quad that runs like this during races thanks
Old 03-01-2009, 03:32 PM
Scooter86's Avatar
Knows Old ATV Questions!
When was the last time you adjusted the valves?
Old 03-01-2009, 05:53 PM
450rbaby's Avatar
i never have before....
Old 03-02-2009, 06:37 PM
Scooter86's Avatar
That is likely your problem. These high strung 450's need frequent valve adjustments to stay in spec. Once they start to wear in a bit and get out of spec you will get hard starting.
Old 03-02-2009, 08:43 PM
450rbaby's Avatar
ok so if this is so how do i go about adjusting them
Old 03-03-2009, 04:33 AM
Scooter86's Avatar
If you want to do it yourself, buy a shop manual for it and/or find someone to walk you through it. There are plenty of online resources dedicated to the 450R Honda, you should be able to find a step by step on one of those as well. Otherwise take it to a shop, it should cost you about 1 to 1.5 hours labor.
armpump450r
Technical and How-To Articles
04-01-2017 06:11 AM
generalpops
06-05-2015 08:23 PM
garyt1975
06-05-2015 08:53 AM
generalpops
06-03-2015 08:25 PM
1000gade
05-27-2015 12:37 PM
Quick Reply: 450r starting problems??????
