2002 sportsman 500 oil leak
make sure it's not your washer on drain plug. Wipe the area down real good where it seems to be leaking then start it up and let it run a bit then check the weep hole after it sits for 1/2 hr. or so, it will probably be leaking. The weep hole is between the water pump seal and oil seal.
Even if it was just the oil seal you would still have to replace the waterpump seal also. When you remove the waterpump then the black impeller you will see the wp seal. You have to remove it and the oil seal is behind it. The water pump seal will be no good once you remove it. The waterpump seal is a **** to remove. Might want to take to dealer.
